  • 3 months later...
any ideas for a series 1 rs 4 to rwd as i have impul stock ecu in it and its 1 big plug. than i jacked my car up to take the shaft out it has 3 bolts to undo but on the other side of the box the shaft runs straight through the box any ideas or help for me cheers
What are you trying to do? To get 2wd you need to remove the front driveshaft from the transfer case to the front diff.
yer sweet found it!!! but cant get the bolts undone gunna have to take to as shop spent hrs tring to undo...
Some people found it easy but didn't find it that easy myself! Had to go and buy a brand new good quality ring and open ender (12mm I think) and then make sure you identify which is the nut (as the head of the bolt is pretty much prevented from turning).
  • 2 months later...
Guys, my attesa pump has died, so in the meantime is it ok to drive it around indefinitely (until i can get a new pump) with the front shaft removed and either the 4wd fuse removed, and/or, the attesa pump removed ? From what ive read, should be fine, but if anyone sees a problem...
Yep I drove around like that for a few weeks - shouldn't be any problem.
well ive pulled shaft, removed fuse and released pressure in fluid. So I assume ecu knows pump is inoperable, hence 4wd light on, and does not, and cannot, try to turn pump on.
Apart from removing the front drive shaft and 4WD fuse, do we have to release the fluid?
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
