  • Replies 50
Thanks for the luck Stuart :D
It all comes down to "show me the money" with what we will end up with.
There has been so much going on since Homebush, that it changes many times each day.
Alot of AWD's are faster in 2WD.........and that may mean allowing the Motec or whatever switching to FWD or RWD at various points on a track, depending on the circuit of course.
In Prod cars, alot of teams think FWD is faster in there AWD's.
Well lets hope we are both right , as we just acquired an ex SBR AU.
This year will be a bit quite - hope to catch up with you in the AU or the 33 thru the year.
At the moment Karen and I will be doing mixed events in both cars.
Cheers
oooooh more details on the ex SBR AU Stu?
Hi Evil
Chasis no 4 was Blue, now Black.
Going for a play Monday 31st, Tuesday 1st coming - planning on a fairly quiet set up year, playing with tyres, and stuff - November will see a 5999cc stroker to hopefully go and play in 2012
Cheers
Hi evil , First test at wakefield went ok ,only got about 21 lap myself all day , had some small issues, diff oil leak and a lazy shock - but ended up with a PB for car and self.
Less than a second off record, some decent tyres and a little bit of sorting - totally looking forward to some time in the car
Cheers
This is the record on their website
V8 Supercars
Driver: Steve Owen
Holden VZ 6/04/2008 59.0391
I'm pretty sure their website is out of date. They've run quicker than that.
59.03 is the record.
Qualifying times never count for records, as it must be done during the race.
I don't think Stuart would have done sub 60's on his first go. I am guessing 63's?
Ahh ok, makes sense.
Then again i doubt Stuart was racing?
Anyway 58.4 for a qualifier and 59 flat racing, cool.
The last 6 laps of the day, times are
1.02.894
1.00.686
1.00.072
1.00.032
1.00.134
1.07.260 (cool down)
Best Minimum Rolling in that sesion was a 59.871 (point to point not beacon to beacon)
Motec Data @ 4.10.52PM 1/2/2011 Wakefield Park
Hi Duncan
Heres a picture.
No - not racing, tyres are 2 years old, had suspension and wheel alignment issue now sorted - can't wait to give the 11 year old car another go
Cheers
Boz we did 63's first outing in the GTR R33 at Wakefield on AO50's - full trim and rego, why would you bother purchasing an old supercar to do the same.
Hi Duncan
Heres a picture.
Cheers
Stuart,
you've got to get new tyres and go out smash the time :)
Good luck.
Stuart,
Good luck.
Thanks Ducan,
Settlilng to car and budget this year, chase a couple of sponsors, and hopefully play next year.
Got a heap of spare tyres with the car, thanks to Terry - gunna use these for settle in period and see if we can use some D11 Dunlops for qualifying times.
Cheers
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
