i bought the rims second hand from ebay with those tyres, and if you look at how they are bold its definately not from burnouts front ones are just as bold, like i said come and inspect it for yourself, dont like it dont buy it very simple
Let me put this in capital letters so people can understand. CAR NEEDS BLUE SLIP HENCE NOT REGISTERED AND CANNOT BE DRIVEN ON THE ROAD LEGALLY !
Please don't lowball me with offers such as $2k cash. The price was set for a quick sale but has'nt been so far. NO TIME WASTERS PLEASE ! GENUINE BUYERS ONLY !
My number - 0435 324 628
So you can do your checks before you come - VIN - 6U9000ECR33022605 ENGINE # - RB25091849A
no worries mate, thats fair enough.. im glad thats not the case :), looks like i have sold my subaru but nothings concrete yet, you know how minds can change.. i will be in contect with you via PM asap when i get the info..
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
