This thread is hilarious.
I seriously think some people are far too precious with their cars. I mean seriously.. thinking highway driving would cause excessive wear on an engine? This forum Delivers :)
+1. Forum has a lot of idiots as of late.
OP will be fine, car will be happy to do that rather than limiter bashing.
the only reason you'd see falcons on the side of the road comes down to the lack of maintenance by a lot of owners, not the actual cars. if skylines were treated like a lot of commodores and falcons are there'd be a hell of a lot more of them on the side of the road broken down than commodores and falcons.
ford owners must neglect their cars more than holden owners, either that or holdens are more tolerant to abuse. i see a disproportionate amount of fords broken down.
they are just a standard family car with a turbo attatched.
That's a bit dishonest Marc. A Vecra VXR is a family car with a turbo engine, but I wouldn't characterise a GTST as that. I'd call it a de-tuned touring car which may or may not be available in saloon format. It's only a family car in the sense that in is not say mid-engined etc. Nissan never marketed it as a family car really, the NA saloon versions were kind of inferior after-thoughts. Even the RWD format goes against the grain of jelly mold family saloons, there is NO reason to go RWD if you are just making family cars.
no, a GTR is a de-tuned touring car. a gts-t is a family car version of said de-tuned touring car. they are no more a detuned touring car than an xr6t. the non GTR are just a sports family saloon. they are less of a the S series and Z series cars are more sports cars than a non GTR skyline.
a vectra VXR isn't a family car either, it is a sports hatch, in fact the VXR is the sports hatch version of a normal hatch. they are simply GM's answer to the focus. anyone who buys a vectra as a family car is stupid.
    • Cheapest option, find a NEO head. Put in good springs, decent cams, and send it to the moon. I rev mine to 8600RPM, gets me about 232km/h down the main straight at SMSP bouncing off the limiter in 4th. I've never dared to grab 5th 🥲
    • Gday mate, Personally in my car i run 450kw in an s2 rb25 so also hydraulic lifters and have always run it to 7500 RPM and using some baby 256 poncams with new but stock springs and retainers. While i cant speak on any experience with solid lifters i personally have had no issues with my hydraulic lifters which were just cleaned and set in an oil bath before assembly over 7 years ago. Over 8k RPM is cool IMO and if you are using the stock gearbox or just a box with longer ratios the higher rpm certainly could aid to maintain boost into the next gear as that was always something i struggled with as i have a 3582r also but a hypergear equivalent could aid that issue. In summary i would make a choice on the cam you want to use first then decide which springs and retainers work best with it and then you can toss up if you really need the solid lifters, if the car is mainly street i would learn towards keeping the hydraulic lifters as when installed properly and nothing too hektik going on around them they do the trick.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
