  • Replies 43
30mins max... maybe 45
:bs!:
I dunno about 30 mins.
Maybe if your a frigging machine and have ALL the tools pre-setup
I'd prefer to take my time and do it properly.
I reckon an hour is fair. With a beer in the middle lol!
I can show someone if they BYO tools, i aint got many ATM.
Oh, and you supply plugs too :aroused:
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-691968
1 slave labour comin up :D
I agree 1 hour for a half decent job, maybe the 32 / 33's are a bit quicker? 34 has strut bar and engine shroud in the way as well as everything else...Bov, Plenum [which may involve ic piping removal], rocker cover 8-10 allen key bolts from memory...plus ALL of the individual coil packs...4 bolts each!
My first go took me approx 2 hours, with the 2nd attempt maybe an hour - except I was cleaning everything while I was doing the plugs...if you only change the plugs then probably an hour on a good day - try it in 40 degree heat /wipes brow :)
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-691978
i can do my 32 in half an hour... there aint much difference bw that and a 33...
u dont have to remove everything u simply undo one end and move it out the way.
MAX time 45mins... and my 32 also has a strut bar.... plenum doesnt move... piping undo it at the plenum end and undo ONE end of the hose on the BOV.... undo the 2 bolts that bolt that bit of pipe to the engine and lift it up.
undo the screws on the rocker cover and then undo the bolts on the ignition packs and lift em out... undo the sparks and rreplace... bolt everything back in and voila!
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-692015
ill time ya tonight inark :D
btw what beer you like?
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-692019
I done mine last night , at least an hour at a nice easy pace, you can do it quicker for sure. But i regapped them, cleaned the coil connectors etc. Also, it wise to take off the intercooler pipe too. I didnt do it first and i put the number 4 plug in angled. Luckily it hasnt done any damage.
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-692021
if anyone can do it in 30mins, and do a proper job then i will give u half a slab.. has to be properly timed.
It usually takes me a bit over an hour... thats getting the tools out, undoing everything, removing plugs.. having a look at the old ones and numbering and dating them, then gap the new ones and put them. Do everything up... and presto...
Add another 5 or 10 mins if i put my tools away, but im too lazy after that to bother and normally do that a few days later :D
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-692024
lmao ur timing from when i get the tools out and put them back!?
lol man im talking from the time i start taking things to bits.... gapping should be done before hand but i normally dont do it cause i dont trust myself to do it properly... i did it once but never did it again incase i stuffed them.
only tools u really need are:
10mm ratchet and ext bar - undoing the bolts that hold the piping to the block
8mm socket - losening the hose straps on the piping and those bolts that hold that grey box onto the rocker cover.
alan key - removing rocker cover
16mm spark plug socket with a 1/2inch drive ratchet and long ext bar - for removing the sparkies
12mm socket - for the bolts that hold the coil packs to the block...
pretty sure thats it.
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-692032
Are you sure you're the best person for the job Ni?
I mean considering what happened with your last set of plugs :D
Nah, you'll be fine im sure...
edit*** http://www.skylinesaustralia.com/forums/sh...ght=spark+plugs
https://www.sau.com.au/forums/topic/34569-spark-plug-change/#findComment-692052
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
