"dimple" Neodymium Magnetic Drain Plug Group Buy #2!
  • Replies 155
Posted Images
Yep your payment was received.
Still awaiting around 10 payments. While the PM's aren't working, please just communicate through this thread.
I'm just about to PM every one who hasn't paid yet :)
Just make a list of all the people who you HAVE payed and HAVE sent required information to you. It stops the above posts (have you got my money) from happening.
PS Still don't know if my payment and information was received, because no list has been provided.
Still awaiting on payments (or payments to clear) from the following in bold :)
All the rest have come through.
1. R31NISMOID
2. BWRGTR
3. BASTI
4. STOLEN-GTR
5. N1GTR
6. SHIHAN
7. ELRODEO666
8. JPOWER
9. MR MOO
10. JAP MUSCLE
11. GWHOLXC
12. RBCEFFY25
13. HESLO
14. ADRIAN P
15. WHITER33GTS-T
16. NICK_7G
17. CHUCKIE
18. SPL1CE
19. A20089
20. DAVEB
21. MESSIAH
22. STRYKR 33
23. GTR32R
24. BIGADZ
25. MATTIS96
26. R32MAN09
27. SKINS
28. .:: GimpS-R34 ::...
29. NYTSKY
30. 33DRIVER
31. MOODLES2
32. TROZZLE
33. PMR33
34. BLAH BLAH
36. MAYURI KRAB
Phil,
Any idea when this will go ahead or you still waiting on a few slackers with payments ??
There is still a few payments that I am awaiting but those people have all ready been in contact with me.
Because the order was so large and the gearbox and diff plugs are not ones they keep in stock they are currently getting made.
They should be ready to be sent this week/next week. Then around 3 weeks to get here again.
Yep yours is fine. The three people have been in contact with me and everything is sorted.
Every one elses payments have gone through fine.
I will post up the date they should be leaving the US as soon as I find out :)
UPDATE
Heard back from Richard, ETA for leaving the US is the 17th, so ETA for us should be around the 7th Jan give or take :)
UPDATE
They got sent prior to the weekend and Richard sent them with DHL instead of regular US post to make it quicker as a Christmas present :)
UPDATE
They came today! Was not expecting it this week at all; really going to thank Richard for spending the extra money on sending them with DHL :)
Here is the gearbox/diff plugs, look very nice :)
I might not get time to send them before this weekend though because of moving house, but will definetely send them first thing next week once the post office opens back up (if any one needs them urgently just let me know and I will try to send them out on Friday).
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
