"dimple" Neodymium Magnetic Drain Plug Group Buy #2!
  • Replies 155
I must have missed my postie by like 5mins today as i emptied it, went upstairs and come back and i had more surprised :D
He managed to get them into my letterbox though so all good
Cheers Phil :)
No worries guys, great to hear they rocked up safely. I always worry they are going to magnetically attach themselves to something and get lost lol.
Mine turned up yesterday so I started looking thru the shed to see what I can lift with the sump plug. First thing I found was a hammer :worship:
Hope this doesnt pull the crank out of my block. hahaha
Thanks Phil
These black hole things are definitely fragile...separated all of them to put them onto oil filter today, and one of the middle ones in the stack was already broken in half :(
I might open it up tonight if I get some time. Hopefully this one won't fill so damn quickly so I get a chance to PM all the people that missed out. A bunch of my mates want to get some more so I'll have to check with them aswell.
  • 2 months later...
Has another buy been started? Depending on peoples feed back i'm keen.
Look at the thread above or below which has at least 5 pages of comments and states the title "Group buy #3"
Mine arrived all good.
Apsolute shit. Braught one of these of a guy who didnt use it. 2 services the tread snapped off the magnet! Very very poor build qaulity! Be very careful boys!
What do you mean the "thread snapped off the magnet"? That doesn't make any sense there is no thread on the magnet and the magnet is epoxied inside the bolt. Do you mean the bolt snapped? The bolts aren't titanium, if you start applying force to the bolt if it isn't going in correctly any steel bolt will snap. Without knowing the full story behind something don't simply make up bullshit that they are shit and are poor build quality due to one incident.
If you want to PM me and discuss a replacement I will gladly speak to Richard about what could have caused the failure (what ever it is that you mean).
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
