"dimple" Neodymium Magnetic Drain Plug Group Buy #2!
  • Replies 155
I must have missed my postie by like 5mins today as i emptied it, went upstairs and come back and i had more surprised :D
He managed to get them into my letterbox though so all good
Cheers Phil :)
No worries guys, great to hear they rocked up safely. I always worry they are going to magnetically attach themselves to something and get lost lol.
Mine turned up yesterday so I started looking thru the shed to see what I can lift with the sump plug. First thing I found was a hammer :worship:
Hope this doesnt pull the crank out of my block. hahaha
Thanks Phil
These black hole things are definitely fragile...separated all of them to put them onto oil filter today, and one of the middle ones in the stack was already broken in half :(
I might open it up tonight if I get some time. Hopefully this one won't fill so damn quickly so I get a chance to PM all the people that missed out. A bunch of my mates want to get some more so I'll have to check with them aswell.
  • 2 months later...
Has another buy been started? Depending on peoples feed back i'm keen.
Look at the thread above or below which has at least 5 pages of comments and states the title "Group buy #3"
Mine arrived all good.
Apsolute shit. Braught one of these of a guy who didnt use it. 2 services the tread snapped off the magnet! Very very poor build qaulity! Be very careful boys!
What do you mean the "thread snapped off the magnet"? That doesn't make any sense there is no thread on the magnet and the magnet is epoxied inside the bolt. Do you mean the bolt snapped? The bolts aren't titanium, if you start applying force to the bolt if it isn't going in correctly any steel bolt will snap. Without knowing the full story behind something don't simply make up bullshit that they are shit and are poor build quality due to one incident.
If you want to PM me and discuss a replacement I will gladly speak to Richard about what could have caused the failure (what ever it is that you mean).
Guest
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
