So its been a while since iv posted but iv been busy etc anyhow for those of you who know my car will be aware it has been converted to S13 Suspension.. and most will be aware this creates an issue with tie rods not fitting!!
after loads of ideas iv finally just took a punt and just used a die grinder to re shape the arms and well it was a resounding success!! it drives perfect im very happy to finally sort it all out !!! the next step is going to be finally sorting out my 5 stud conversion as i have my 18s still sitting in my house waiting to go on..
i took some photos to
https://www.sau.com.au/forums/topic/345713-success/
i have 2 sets of tyres, i intend to put on 235/35or40?/18 semi slicks i got of a 2010 STI there a 9 inch rim so they will be stretched on..
there a dish type old school wheel 0 offset they fit fine as iv tested them they should look really good (they are not in anyway a modern wheel!
Edited by FJ20DR30
https://www.sau.com.au/forums/topic/345713-success/#findComment-5569167
Each to his own I guess?
But having driven on Australian roads for over 40 years and traveled over 3000000km in that time, in all sorts of vehicles, I know exactly why they make road tyres and track tyres and why profiles are so important.
With your 35/40 profiles on your 18 inch rims, I would recommend you buy a kidney belt and wear it everytime you drive. Your tyres are going to be so hard, your ride quality will be almost nil, you will be able to roll over a 5c piece and know if it's heads or tales, when driving on cement/concrete roads your going to be tracking the joins/expansion joints like nobodies business, miss cue just a little and clip the high side of a driveway kerb, or hit a pot hole and you're most certainly going to be buying another tyre and possibly another wheel rim as well.
As for semi slick tyres on the road, yes they are street legal, but only because they have grooves in them. The side walls are not designed to take ANY abuse, scraping/rubbing a gutter, or bumping a kerb and your likely to be looking for replacements. They do not like the heat cycling that occurs in road driving conditions, because once they reach operating temperature, they like to stay there, not get hot & cold like a road tyre. They are also going to have a 270kph speed rating when in Victoria, with more speed cameras than anyone would care to know about, get caught doing much more than 120 and your pride and joy will be parked for quite some time.
All seems a huge waste to me when other sizes are available and designed for the purpose at hand with costs significantly lower and therefore more economical.
I wonder if you or anyone consideres the insurance side of things??
Even Shannon's & Just Cars frown on anything more than a plus 1 concept. They will take your money and say nothing until it's time to pay out on a claim.
JMHO
D
https://www.sau.com.au/forums/topic/345713-success/#findComment-5569279
JMHO
D
lol hard is good ! the coilovers are also set to full hard big front sway bar! talking about tyre temps etc??? there factory tyres of an sti there road tyres and they cost me nothing!!! i also run 2.5 degrees of negitive camber just to get it turning
to be honest i understand where you are coming from but its not luxury car its my own old school torge car. i dont care about bouncing out of my seat in town as long as it looks good and blitzes the corners when i take it to the hills.
like you say each to there own.
https://www.sau.com.au/forums/topic/345713-success/#findComment-5569351
Well ya got me! If I was gettin my tyres for free, it don't matter really what they are eh? I have a couple of sets of 245/45 x 16 Yokohama A008-RSII that cost me nearly nothing, they are about 5 years old, side walls aren't as flexible as might be liked, useless as track tyres, but curious how they might perform as road tyres.
D
https://www.sau.com.au/forums/topic/345713-success/#findComment-5569751
Hey Dennis, if your looking to off load those 245's at any time give me a bell. Although I was hoping to get a shit pair before our major car show here in WA which is in mid JAN. I want them to destroy. I run that size at the mo but don't want to inihalate these ones. You could send them with the badges.
https://www.sau.com.au/forums/topic/345713-success/#findComment-5570145
Hey Ricky, I could, but I don't think they will fit in the same size package :rofl2::rofl2:
I don't know that I am at the moment, but all might change before then. You going to spring for the freight?
D
https://www.sau.com.au/forums/topic/345713-success/#findComment-5570358
Yeah alright, I'll look after the freight expense Dennis, knowing you got those tyres for "next to nothing" makes me feel all the better about the aquisition. You being the fair sorta bloke you are I'm sure you'll pass on the good fortune that you encountered with these tyres. LOL, I'm not in dire need of them. If you decide they're in the way after you've tripped over them a dozen times, let me know and we'll see what develops.
Cheers Ricky
https://www.sau.com.au/forums/topic/345713-success/#findComment-5571873
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
