So today I parked the stagea on a gradient sloping to the left. I had about 1/4 tank of fuel left, and did notice that the gauge went right down to empty on the slope. No biggie, I thought to myself.
Well when I went to start the car again, it wouldnt start. It cranked but only the odd cylinder fired.
I had to roll the car in neutral onto flat ground before it would fire.
Normal? Just a quirk of the car?
https://www.sau.com.au/forums/topic/345735-dont-park-on-a-slope/
Sadly....I to have had this problem...Lol...was more of a slope to the left though
Had to get me some fuel...Started then cut out....had to get him to push me backwards till i was on a diff angle so the fuel pump was covered again :/
Im getting the exact same problem on my driveway with a full tank of juice.. and sporadic.. took it for a two hour drive thursday night .. come home park on the drive , after refueling to a full tank... refuses to start. heaps of battery. Then i leave it for an hour play with the shifter .. finally starts in nuetral... Then starts again in park.
Then the following day.. refuses to start again.. full battery power lights are beaming.. im thinking shift lock or starter motor.. anyone else got any ideas?
did however notice it made a few slow spins of the starter when it did start like a dying battery or dying starter motor.. then the following day made clicks. now does nothing.
yeah shes a 2T brick where she sits.. need it towed ..starter motor is screwed.
Edited by PetroDola
It happened to me a lot. I either dont let it go below a quarter full or turn the car so its nose down!!! Took me three goes at running out of fuel before I got the hint that I really need to watch the tank though...
are you kidding? this happening on m35 too? God they fixed this sh!t on most cars in the 80s!
Not sure about the issues with starting it on the slope, but our fuel gauge can definitely respond poorly. I parked on the road outside my house last night for a few hours, trades people were on the drive way when I got home, when I went to move the car later that night the gauge had mysteriously dropped 25%.
no it was pure coincidence which happened to be on the steep drive..later realising my starter motor died .. didnt realise that nissan starters have a tendancy to just work then not work .. with no warning.. unlike other cars that generally give you slow turnover symptom similar to a battery dying.
Edited by PetroDola
I don't know if it would help, but I think if I had these issues when the tank got low I think I would check my cradle; see that it hadn't moved from where it's supposed to be, that the pump was mounted properly, check the actual level in the tank. 'Cause even when the level is really low, the cradle generally keeps enough around the pump to keep it submersed. And I know that even when you get the cradle out of the car, it's actually pretty difficult to empty that fuel OUT. So it should still be seeing some fuel...?
yep happened to me after work, just worked an 11 hour shift and that was the last thing i needed. The pick up must be on the drivers side cause my car was sloping toward the gutter and i had a quarter of a tank. It started but it soon died before i could take off. Pain in the arse
  • 4 weeks later...
slightly off the topic but to do with fuel gage part.
I notices that when I thrash it for a good ten minutes or so my fuel take gage drops about 20%. then as I go back to normal it slowly comes back up. could this be something to do with the G-force?(Even though there wouldnt be much at all with my fridge)
Can't confirm, but been told the V35/M35 fuel gauge acts as a fuel consumption gauge too, so if you thrash it it'll say you have less but if you drive conservatively it'll give you more.
But this could be 100% wrong, just what I heard through a random stagea/nissan convo.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
