I am looking for a R33 GTR wing blade that i have seen before on a few GTR's ..
it is almost like the standard blade, though there is one big blade and one smaller blade (above and at the back), sort of like the Nur Spec R34 (but obviously for the R33!)
is it the 400R wing? if so do anyone make similar copies etc?
sorry if it doesn't make too much sense.. hopefully someone will know what i am talking about!
https://www.sau.com.au/forums/topic/34576-who-makes-this-rear-gtr-blade/
Nismo make one (400R had it).
Electra make one - http://www.electra-cps.com/e_framemain.htm - but you'd better get that platinum AMEX ready... 260,000 yen
Predator has a DSpeed kit with a twin-blade wing (but is a different rear spoiler unit)
There's also the gurney flap option (ala R33 N1 carbon blade) - Hasemi Sport make one that fits on the top of a standard wing blade:
http://www.hasemi-ms.com/R33GTGTRW.JPG
AutoSelect make this interesting alternative:
ricknismo
that's the puppy! i forgot to mention it was carboin fibre anyways!
if you can PM me a price i may be very interested! (unless it is bloody expensive :D )
thanks to the rest of you as well, i havn't seen that many blades before! good jobs!
You'll have to send an email to [email protected] or [email protected] or ring 0405440526 or 0403 575 555
I really have no idea about cost as I already had mine but tell jason that Rick told you and I'm sure he'll give an awesome price...He's a good bloke.
Actually let me know when you get a price, my carbon is a bit dated...too much time in the sun in Japan I think.
  • 2 months later...
Custom Carbon prices are pretty reasonable (for real carbon fibre) and I like the way they construct their panels, especially the bonnet and bootlids. They will be doing boot,bonnet and frontbar for my 4 door.
Well my wing is definetely there getting copied at the moment so ring him and just say you want a copy of Ricks GTR wing....group buy would be better I guess.
Let me know how you go.
Jason just got a contract to fix that fj20 drag 200sx completely in carbon fibre so he's probably just busy.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
