iv polished my car by hand, and with oribital pads neither will remove the swirl marks i have in my car
iv gone through the polishing and waxing thread and nothing seems to work
you can see the scratches only at night time and it looks very very bad
any ideas guys
cheers
https://www.sau.com.au/forums/topic/345777-swirl-scratches/
Hey mate, there was a similar thread set up a few weeks ago...I suggest you see that for better details...
In brief, it seems you've applied too much wax and it's left grease residue on your finish that looks like oil or fat swirls, right?
Many will give you more methodical ways of removing this, but what I usually do is go and buy a small bottle of Eucalyptus oil from either Coles or Safey and with a clean and soft cloth, apply a few drops each time and clean it off slowly. It will work...and the good thing is it will leave your car smell nice and won't damage your paint job.
Good luck - it worked for me.
https://www.sau.com.au/forums/topic/345777-swirl-scratches/#findComment-5569465
The problem isn't just caused by too much polish, its as simple as not washing your car with a clean and suitable wash mit, usually in winter time or after its rained quite a lot mud/sand start covering the road and once it sticks to your car this can sometime cause problems to the unwary car enthusiast who just wants to keep his/her car clean.
When your wash mit gets clogged up there is nowhere for the grit to go and so it sits on the surface of your wash mit causing swirl marks ( depending on the motion your using), and in fact they are not "marks" but fine scratches.
To prevent this you should be using two buckets of water, one with detergent and another with just plain warm water (to rinse the mit in before it goes back into the detergent bucket), This stops debris staying on your mit and keeps the clean water clean.
I would not recommend sponges or anything with a flat surface if you are washing are car covered in grit, as this will practically turn into sand paper and just rub the grit around on the paint surface.
Some people will disagree with this, but i use a lambs wool mit, its great because the individual fibers are always randomly changing direction and are not in the same position when moving across the paint surface, so any grit picked up will be dispersed throughout the mit and not in direct contact with the paint all the time. Occasionally i use a thick "noodle" hand mit.. both create a high level off suds (lubrication + cleaning power) and trap debris inside the mit - this is why people will say this is not a good thing to use but if you rinse the mit thoroughly (a squeeze and a few seconds swirling around) 99.9% of potential scratching grit will be removed
Edited by R34 -_-
https://www.sau.com.au/forums/topic/345777-swirl-scratches/#findComment-5569694
just throwing this out there but clay blocking? by meguires.
ive used it on my skyline which does leave the surface nice and smooth (like glass)
i havent read the polishing and waxing thread butt if you have heard of g3 cutting compound, that might work for ya
https://www.sau.com.au/forums/topic/345777-swirl-scratches/#findComment-5571921
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
