Please excuse my ignorance, but I just saw this article:
http://formen.ign.com/news/16796.html?fromint=1
And it mentions the motor:
The Skyline GTR’s race-tested RB36DETT DOHC, 24 valve 2.6 liter intercooled, twin-turbo I6 at a very conservative 280 base horsepower and a very respectable 289 lb/ft of torque.
This is a typo right? What is the biggest RB motor out there?
https://www.sau.com.au/forums/topic/34579-rb36dett/
By the sounds of the article, they are refering to the RB26DETT so it looks like a typo. No such thing as an RB36DETT.
https://www.sau.com.au/forums/topic/34579-rb36dett/#findComment-691925
While we're kind of on the topic, what's the biggest RB engine you could make? e.g. RB30 block, RB26 head etc - no idea what crank and other parts you'd need, but roughly how big could you make one. I realise it would totally change the nature of the engine if it was 3.5L or so, but I'm just kind of curious.
https://www.sau.com.au/forums/topic/34579-rb36dett/#findComment-691943
We have tried up to 3.3 litres - we could have gone more, but it was diminishing returns, hence pointless.
Just for completeness, we also went as low as 2.4 litres...
Mario.
I suppose it does make sense that if you're increasing the stroke it wouldn't be as easy to rev as hard. Also, you aren't really increasing the volume of the engine that much % wise once you are adding only a few tenths of a litre.
How did the GTR respond to the reduced capacity? I think it was Nismo that reduced the capacity of a VH45DE to 3.5L and it revved like an F1 car. Your GTR already is a very revvy machine, so it must have been even better at 2.4L. If I remember correctly, you were having trouble shifting at very high revs at some point (my memory is bad, sorry). Did it make shifting harder?
https://www.sau.com.au/forums/topic/34579-rb36dett/#findComment-692028
    • Found it thanks, the front tie rod end should be torqued to 40nmish
    • Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed   bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good   appreciate the help chaps
    • Back in 2016 bought a set of front and rear bracket set and changed all 4 corner discs and caliper   i was checking the car and seen rust like or in another word crumbled part of the bracket which came off with a air blow   is this normal? This had happened in two areas and car from 2016 has mostly been in garage/ doing less than 2000 miles over past 8 years or so pic with areas highlighted in red   https://ibb.co/NtmWXZt   also anyone knows the torque spec for the bracket as want to retorque them, one bolt had come off half way !
    • So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars... https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • If you're friendly with a workshop that has a large scraps bin you can always ask to dispose of there. Otherwise theres always the places like sims metal etc depending where you are at https://recyclingnearyou.com.au/cars
