last day of rego for the r33 before it got its new suspension tyres / radiator / stock intake.
should be back on the road in january. - new rego!
then z32 afm , power fc goes on / tune / dyno - hoping for a 250kw tune
Link removed by Moderators, PM sent.
i can now vouch for their toughness.
clutch required a bleed after that episode.
Edited by GoldZilla
https://www.sau.com.au/forums/topic/345801-skyrice/
  • Replies 48
Hey Keir, you probably won't get a really positive response to that in this section of the forum.
Personally, I don't think its some of your best work, we all get grief at some point driving imports, because of the "guilt by association" reputation they have. This is EXACTLY how it happens. I like a burnout as much as the next guy, but faark, in the street? Youtube? How original. Great piece of footage for Today Tonight's next "Import Driving Hoons" story.
I'll be honest with you, if you did that in my street; I'd tell you to piss off and take it to a track. If I saw you do it again, I'd be giving your rego to the police.
We all have a responsibility to think a little bit about this kind of thing, otherwise, the cars, and the lifestyle we love will be taken away by simpering, sooky, politicians looking for an easy vote. Then you'll be driving a bloody Camry wondering how it all went so wrong.
That said, hope the rebuild goes well, looking forward to seeing some pics of it ON A TRACK!
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5569969
this was in the back quarter of an industrial area in the middle of the night in a dead end street. he spent 30 minutes trying to find the most out of the way place on location on a return test drive.. my mate couldnt help himself.
daleo - fair call i cant understand where your coming from. - it was reckless..
i actually wasnt driving. :whistling:
was the first night we got it boosting right.. and my mate decided he was keen to see if it could finally boost a burnout.
its actually from weeks ago i wasnt going to post it but thought it was amusing. :)
i shouldve gone with my first hunch and not posted this.. heh
Edited by PetroDola
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571727
This took on a bit of a life of its own eh?
I'm the first to admit to some monumentally stupid car behaviour in the past, some of the other posts give the impression they've never done a skid.
You won't get any more criticism from me.
Get going on that rebuild.
Cheers, Dale
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571761
Cheers, Dale
life of its own it did.. guess i shouldve put a bit more thought into posting that video.
didnt feel criticised dale, more enlightened to your mature perspective.
cheers. keir.
Edited by PetroDola
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571797
The fact that this is "in the back quarter of an industrial area in the middle of the night in a dead end street" is no excuse - it's still on the street and as has been said, it's videos and posts like these that bring a bad name to the whole car community, especially Skylines.
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571870
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
