OK so Basically.. I have a 93 SSS Pulsar With a Gti-r engine inplace, but not finished
and parts left over from a 32 GTR Wreck.
I have 3 weeks to get it all gone so im offering the WHOLE lot for 3.5k!
The car is still regd. just needs money spent finishing it, its pretty dusty atm as i have no time to finish it and have
been trying to for the past 6 months.
Im going to Bali on the 20th of december and it has to be gone before i leave.
Info.
Bought the SSS Turbo Pulsar with a W10 SR20DET motor 2 years ago, car had 180hp ATW bottom end started knocking so i bought a new motor GTi-R SR20DET The enging came with a reciept for a $3000 rebuild so its fresh. I dont have the time to finish this as I now have a new car and need to get this gone as my dad wants his unit back after cristmas break I bought the car for $7000 spent 5K on repairs and now bought the engine for $3000 plus shipping the engine is in the car but still have to connect fuel lines, wiring harness, front wheels, CV / drive shafts to G/Box and other bits and pieces. I NEED THIS GONE soon so im selling the whole lot for $3000! thats Registered Car, with custom plates SSSLOW, Newly rebuilt Turbo engine, Speakers, Deck, Amps, Pwr Windows, GTR Style Front body kit (optional) Old engine with bottom end knock, Wiring harnesses, Front mount intercooler and more all for the price of the engine alone! al you eed to do is finish it. If i had more time I would do it myself. :) but i dont so im letting it go cheap.
R32 GTR Parts from my other post with prices. but as i said the whole lot incl. car with old engine as well for 3.5K!
Bonnet Hinges - $20
Rear window wiper motor - $30
Fuse box area aircon vent - $60
A/C Condensor Fan - $50
Centre console "tunnel" type thing at rear of radio to floor? - $45
Aircon Temp Sensor - $20
Boost sensor - $15
Side Repeator lights ( Orange - Amber ) $20ea or $30 both
Pedals Accelerator, Clutch, Brake with all brackets $100 for the set "GTR" rubber in good cond.
Odometer Cable - $20
Air Con Control (DIN size unit under radio) - $80
Std. Exhaust Manifolds - $70
Exhaust temp sensor - $20
HKS "Mushroom" Filter kit fits to std. AFMS - $70
ATTESSA oil Res. - $30
RB26DETT Valve caps - $40
Thermostat housing $30 and other side casting for radiator $30 also
Seat belts $200 set or $60ea
Std. RB26DETT ignition Coils $100
Pwr Steering Fluid Res. W/ Lid and wiring - $50
Charcoal Canister (Transaction Aus Carbon) -$40
Coolant Res. - $50
Winscreen washer res W/Pumps - $70
Some Std. FMIC piping $40 Lot
Wiring loom (Cabin Fusebox loom) W/fuse box and all fuses/relays - $150
"Twin Turbo" Pipe RB26DETT - $80
ABS Unit $200
Aircon Vent (Centre Dbl. vent) $70
Fuel Cap Cover W/ hinge (Gun metal Grey) $20
Starter Motor - $40
Bonnet Release Cable - $20
Tail Lights - $70 ea
Boot lid Rubber Seal - $40
Engine Mounts L + R $40 ea
Passenger side reverse light - $40
Cam Position Sensor - $50
Std. Cam Gears - $30 Pair
Std RB26dett Cams $180
Fuel Rail - $60
A/C Condensor - $50
Pwr steering fluid cooler - $30
Flywheel - $100
RB26DETT Sump and diff $180
Steering column W/ Ign Barrel + Keys - $300
Engine Crossmember - $150
Steering Rack + lines - $100
RB26DETT Head Studs - $60
Accel. cable - $20
Passengers A pillar - $30
Clutch Fan - $40
Boot Hinge + Springs - $60
Front Sway Bar Std. - $60
Passenger Steering bar thing from rack to hub - $20
Air Comp. - $60
Passenger Door (Red / Burgundy) W/Window, no card or handle $200
Drivers door (Gun metal Grey) Wwindow, no card - $210
RB26DETT Cylinder Head 1 piston gave up and shattered so 1 cylinder has mashed valves and rough suface may be repairable -$40 pickup only
RB26DETT Block (1 missing piston, Bent rod, and has bashed through that sleeve) 5 pistons left with rods, Crank and large pulley part open to offers
Throttle Position Sensor - $40
Injector wiring loom cover (Black plastic) - $20
Rb26dett dip stick - $10
Centre Light (Roof) $20
Dash Cluster - 180kms model, $100
Dash Surround, with all switches gd cond no cracks $100
Daniel Call 0422 648 745
https://www.sau.com.au/forums/topic/345827-3500-the-lot-must-go/
Ok so pics at the top are pretty much how i got it.
pics lower are with the bar i had on it before i started the engine swap, now it has the FMIC im not sure it would fit on that bad but i still have the old one going with the car,
being a SSS is this car set up to be front wheel drive or in the GTiR engine conversion has it be converted to AWD?
cheers
I say for that price it is front wheel drive, and that engine that is in the pic isnt a GTIR engine ,or it has had the quad throttle bodies removed and standard sss intake and manifold put on.I say that if thats the old engine it is actually out of a u13 bluebird similar to gtir but not gtir, no dolid lifters, quad throttles, better head etc.
Just to confirm, i did say that they are old pics, the new engine is in fact gti-r it does have he quad throttle bodys better head etc I have put the engine in the car but it is not completly finished yet due to lack of time but the new engine is gti-r the pic is the old motor
  • 6 months later...
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
