Hey guys,
Unfortunately I have just been put in a situation where i had to get myself across the country with one week's notice, buy a car and set my self up a new residence all whilst working full-time.
Now enough with the sorrow story, but I have decided the Stagea doesn't suit my needs over here in WA so I have left it in QLD for sale.
1999 Nissan Stagea RSFOUR
Price: $12500, Negotiable
99XXX kms.
Just had the 100 000km service done including all liquids and timing belt changed.
Black
Black/Grey interior (Excellent condition)
Xanavi model( Being temperamental at the moment however the 6 disc changer still works and plays music.)
Climate control Aircon.(As Above.)
I have a NISTUNE chip i can throw in with your purchase aswell.
I don't have any pictures with me as I am on a new computer in WA. However I have attached a link to my carsales advert which has a few pictures.
http://www.carsales.com.au/all-cars/privat...0&silo=1011
QLD Rego till may 30th 2010.
I am contactable on my mobile which is 0433172159 or email which is sgraham0791
@hotmail.com. Or since the car is at my parents house, you may contact them on (07) 38212114
Cheers
Scott
Chuckie, I would have loved to. However it just doesnt suit my needs or wants here in WA. Ill be touring often up to Exmouth, and I want a 4wd for luanching the ski's into the surf and what not, so the stag had to go. I did just see a really mint red Stagea in Joondalup area the other day just after i bought the x-trail. I almost turned around to give it back i miss the stagea that much.
For everyone else,
I should also mention it is Dual sunroofs, Days front bar ( Has a dayz label on the back but after checking i don't believe it was a factory dayz model.) and leather interior.
Bump Guys. I have bought a new Car, and thus would love this to sell.
Know of anyone looking for a stag feel free to pass on the advert. Some liquid-coloured gold incentive may be on offer if you do ;)
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
