hey guys,as i said in my last post im new to skylines, that also means turbo's aswell.lol. so i am hopeing someone can help me fix my problem.
ahhh everything on it is pretty much stock and i wanted a bit more boost. so i got a g.f.b boost tap and when i put the boost up nothing hapopend was running the standed boost. i looked t the waistgate and that was jammed so i fixed that problem now thats all fine. but it still wont boost any harder is it possibel that there is shit in my turbo? or do i need a new one ?
cheers
cam
https://www.sau.com.au/forums/topic/345878-turbos/
do you have an aftermarket boost gauge? the stock one doesn't read in psi and isn't that accurate, so don't use it for adjusting boost.
secondly, are you sure you have it hooked into the right vaccum line? maybe take a pic of how you have it set up.
or as dean said, just take it to a workshop
https://www.sau.com.au/forums/topic/345878-turbos/#findComment-5570447
yeah it was all hooked up right my mate did it for me. he said its not right because its not boosting past 6 but turbo dose not sound like its f**ked ? lol work shop it is hahaha
https://www.sau.com.au/forums/topic/345878-turbos/#findComment-5570851
if you are referring to "6" on the dash cluster gauge then its boosting cos that gauge aint in psi
and as aforementioned take it to a mechanic before you break it. Seriously, boost controllers are not a DIY job unless ur very experienced. Iv seen some horror outcomes... (thankfully not on mine cos i had the good sense to have a mechanic do it even though im pretty handy...)
https://www.sau.com.au/forums/topic/345878-turbos/#findComment-5571230
yeah i was using my mates boost gadge and it was reading six (he is also a mechanic and he said i had a problem with my turbo .but yesturday i installed a boost gadge that i brought and i got a reading that said about 9. i heard that rb20s run stock boost at 10 ? is that right ?
https://www.sau.com.au/forums/topic/345878-turbos/#findComment-5576043
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
