what sensor out the bottom? IF you have some mechanical experience pulling a gearbox out is a piece of piss. IF YOU DONT know what you are doing take it to someone you does
What sensore at the bottom are you talking about?
In regards to where it bolts up to the block, you just gotta make sure the box is dropped down off its cross member to get to the top bolts. Unless your trying to get them from the top which ive never down before.
il take a photo of it when i get home its on the the bottom right hand sid eof the gear box and its got wires coming out from it. im pretty sure its the speedo sensor? im under the impression that the r33s have this? doing the box tonight
pretty easy on a hoist
not fun if youre doing it on the ground
take out shifter from gear box, theres a circlip holding it in
undo gearbox mount
undo starter motor
undo all gearbox bolts from bellhousing
take slave cylinder off the side of gbox
undo any plugs
take off tailshaft
and out comes the gbox
make sure you put a rag in the end of the box so all the fluid doesnt spill out
They are a easy box from memory when i did mine.
You will need 4 jack stands a decent jack, decent set of spanners and socket set with extentions and oil drain bucket. And a strong mate
this is how i do it
1. Disconnect the battery
2. Remove gear shift boot
3. Remove the gear selector by undoing the circlip
2. Jack up the car as high as you can and put the stands under. make sure it is stable before getting under it.
4. Drain the oil out of the box if you are replacing the box or its oil
3. Undo the bolts on the tail shaft and remove it
4. Unbolt the clutch slave and tie it to one side
4. Than i undo the starter motor and leave the wiring connected to one side where it wont fall
5. Undo the bottom bell housing bolts leave 2 easy accessible bolts in just loosen them.
6. Undo the gearbox cross member and drop the back of the box down
7. Disconnect the wiring and the seedo sender
8. Get your extensions and go from the back of the box to undo the top bell housing bolts.
9. Now get your mate under there with you and undo the final bell housing bolts and using a pry bar or a big screw driver and leaver the box from the back of the motor with your mate holding the back of the box up level. Be careful as they can come quickly or sometimes be a real bastard if it is not coming you have more than likely missed a bolt once it is separating from the motor pull it back and it should drop out they are pretty heavy.
and thats all there is to it someone that knows what they are doing should have it out easily in a hour and a half
