Method Posted February 19, 2004 Share Posted February 19, 2004 Hi All, Whats the difference between a R33 GTS25T M-Spec (or Type M) and the normal R33 GTS25T? mr_gts Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/ Share on other sites More sharing options...
JezR31 Posted February 19, 2004 Share Posted February 19, 2004 all R33 GTS25T models are Type-M ( theres no M-Spec ) All the r33 GTSTs are Type-M the GTSs are Type-S It could have all the options fitted or not. it really depends on what the original owner wanted. also cosmetic changes. do a search its been covered many many many times The R32 is the only model that didnt come with an Type-M model. Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-692379 Share on other sites More sharing options...
Rezz Posted February 19, 2004 Share Posted February 19, 2004 all R33 GTS25T models are Type-M ( theres no M-Spec )Yeeeeah, you tell him Skyline boy... I was *almost* gonna give you 10 points for poise... but... (see below)The R32 is the only model that didnt come with an Type-M model....you forgot about the 05/89 - 07/93 R32 Skyline GTS-T Type M. www.vesta.dti.ne.jp/~mach/drive/mycar.htm]R32 Skyline GTS-T Type M[/color] Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-692621 Share on other sites More sharing options...
Method Posted February 19, 2004 Author Share Posted February 19, 2004 I did do a search before posting guys. But the Search facility said that "M" didnt have enough letters in it to perform a search. So then I searched for M-Spec and found some posts, but nothing relevant. However, thanks for the info! Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-692838 Share on other sites More sharing options...
Rezz Posted February 19, 2004 Share Posted February 19, 2004 I did do a search before posting guys. But the Search facility said that "M" didnt have enough letters in it to perform a search. So then I searched for M-Spec and found some posts, but nothing relevant.However, thanks for the info! You found nothing relevent for the "M-Spec" search because they don't exist (except the R34 GT-R Nur M-Spec)!Just try searching for "R32 Skyline GTS-T"... it seems the almighty server can't compute single letters. Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-692854 Share on other sites More sharing options...
JezR31 Posted February 20, 2004 Share Posted February 20, 2004 oops about the no type-m r32s. I knew there were r32 Type-M gtsts except ive read in places that all r33 gtsts are Type-M but the r32 had the type-M as an "upper scale" model to the normal gtst. Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-693125 Share on other sites More sharing options...
OKBANANA Posted February 20, 2004 Share Posted February 20, 2004 You found nothing relevent for the "M-Spec" search because they don't exist (except the R34 GT-R Nur M-Spec)! Just try searching for "R32 Skyline GTS-T"... it seems the almighty server can't compute single letters. Rezz i was going to say that (about the R34) but it's actually the R34 GT-R MSpec Nur please correct me if i am wrong (you put Nur M-Spec! damn you ) :wassup: :Oops: Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-693513 Share on other sites More sharing options...
AutoTrust Posted February 20, 2004 Share Posted February 20, 2004 Rezz is latin for 'will not post unless intrinsically correct'!! Link to comment https://www.sau.com.au/forums/topic/34593-m-spec/#findComment-693561 Share on other sites More sharing options...
