Ok so the story goes....
I just recently bought a sil80 and on the weekend i took
both front wheels off to find the passenger side has a 20mm spacer and the drivers side has only a 3 or 4mm spacer....
this brings both wheels to sit even when you look at the car front on. Now the first owner in australia crashed into a guard rail
on the front left and did the s13 front end conversion as it was cheaper then getting 180sx parts....
anyway i took the spacers off to find that the drifteks (17x9') rub against the coilovers, when i hit the breaks the car pulls left
but that was due to the fact the drivers side had more + camber then the passengers side so i adjusted the drivers side to even
it out and it has slightly fixed the problem but the coilovers don't sit in the same position from drivers side to passenger side to get even camber
does anyone know what might be the problem and who might be able to fix it???
I can take pics and post up if need be.....
https://www.sau.com.au/forums/topic/345933-front-wheel-problem/
The issue could be bent suspension components to chassis rail being pushed over. Its impossible to say by discussion or photos.
What the best thing to do would be to see the best suspension bloke you can in your area. Either that or a good mechanic.
Some one will need to measure up the car to determine if the issue is in replacable parts or if it needs serious work..
GL
