I have spent plenty of time around cars (Inc overheating ones) to know a bit about it, but..
After a little run I pull up and my r32 is bubbling and so on when you open the bonnet, there is no oil in the water vice versa, never looses coolant, never runs hot (sits a bit over half all the time) I have put a funnel in the radiator and let it run, loosened the bleed bolt, even when all I had done was check the color of the water on first inspection it has done this all the time I have had it... Which is about 18 months, do other peoples do this, I am worried about it doing a head, especially as my first event in it is next weekend, but I cannot find a thing wrong with it
Had the same problem for a while in my car. Used to bubble for a few minutes after 20-30mins of spirited driving. Never ever overheated though. Nonetheless, I bought a new radiator and its never happened ever again.
Edited by GT32
Definately under the bonnet, from around the passengers side of the head moreso than anywhere else
Squeezed the radiator hoses Ian?
Used a wooden dowel between your ear and whatever?
Had another suggestion of a funnel, letting it get temp up and then leaving it overnight, with the front up, it took a fairly healthy drink from the funnel and since then I have not had much of a chance to test it out, but it seems to be ok.... Will find out at the mount this weekend...
You'll probably find that it's the coolant in your overflow bottle boiling once the engine has been shut off, as it's no longer moving through the system.
Edited by Macross
Bingo, was not that originally, but is now, am in the process of putting a new radiator and thermostat in it... in time for racing it tomorrow and Sunday...
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
