Hey everyone im an apprentice mechanic 3rd year... and havn't done much with turbos performance wise
i blew my stock turbos oil seals on a R33 GTS-T im running 13pis with 183.5 kw rear wheels so im gona upgrade my turbo but im not sure what turbos i can get 2 suit
an RB25 any ideas on what turbo i can put on her and do i have to get an adapter plate?
Need advice asap thanks
https://www.sau.com.au/forums/topic/345942-blown-my-turbos-oil-seals/
as always depends on budget.
also sounds like you are running the standard ecu if you are only getting 183kw from 13psi...
probably high flow from GCG or hypergear sounds like your best bet along with a computer.
I also take it you have the full supporting mods for upping the turbo? (turbo back exhaust, front mount intercooler)
yeah i got a big front mount dump pipe 3 inch cat bak .. fuel pump and yes standard ecu ... sooo what size's are the turbos u are talking about and whats there price rang do u know? also i want to put new injectors in her aswell and a fuel presser reg
well any decent hks/garrett bolt on you are looking at $2.5-3.5k. High flows from GCG/Hypergear $1k-2.5k
computer $1k
injectors $600-800
all of the installation work and tuning probably about another $2k
u got a high flow cat? another $300 if not.
got an electronic boost controller? another $500 if not (if you are getting an upgraded turbo n computer dont use a cheap boost t)
is your budget blown to shit yet? (you are at a conservative 6 grand now...)
oh yeah, and expect the unexpected's when doing this kind of work n mods which add power and throw up other issues- add another $1-2k (seriously, id put money on it, happens to everybody)
do you even know what kind of condition your engine is in for these kind of mods (compression/leakdown test...)
Ă—
Ă—
