bought Phillip island track last night and the VW tdi for some FWD love :P felt right at home. flat shift sequential is pretty cool too. just a shame diesel means the gear ratios and revs are all over the place.
I can't see Bathurst on the track list, is it released?
It might be under Mount Panorama, but yes, it is released. Been out for a while now. So much fun!
I'm racing a Tuesday night v8 supercars development league. Fixed setup, great for a level playing field. It follows the fincar series and is run by the same guys. Gets a great turnout of 50+, and good close racing
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7295492
  • 5 weeks later...
Any chance to spectate? Twitch or something?
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7321593
I'm assuming Twitch is some online broadcasting service..? I've never used it before. Would have to test it out beforehand I suppose.
Anything which is too cpu intensive has a good chance of making sim racing utter hell haha.
I'll have a look at it though and get back to you :)
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7321624
  • 1 month later...
  • 6 months later...
Thread bump.
The V8 supercars have had an update ford and holden COTF are out :)
Also starting in the next few weeks a huge V8 premier series. Fully broadcast via V8sonline. You have 3 days of pre qualifying and only the top 80 drivers are accepted and split into a support and main race (both broadcast). Then you have official qualifying and sometimes they do a top 10 shootout. Its no reset buttons and realistic live marshals. So you wreck your car in qually if it doesnt drive back to pits you are out. Its really fun and being hosted does not effect irating or safety.
Link for extra info http://members.iracing.com/jforum/posts/list/3297737.page
Also a few paint jobs i did when I was quiet at home. I now run in a team called Multi 21. Enjoy pics :P Hope to see you out on track.
10313732_10154881672030521_6418043923152
  • Like 1
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7478746
I'm looking forward to doing some enduros with driver swaps, So i'll renew tonight I think
Did the Daytona 24hr with a few mates a couple of weeks back. Pretty hectic. There is a Bathurst 12hr this Sunday.
The driver swap feature is pretty sweet, especially for the Bathurst 1000 haha
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7478938
  • 3 weeks later...
i bought bathurst and the lotus 75 the other day. mt panorama is great! especially in the lotus. the ford v8 supercar (not the updated one) on the other hand... having problems with basic tasks like a) braking in a straight line. b) getting back onto the course when on the grass.
IRL, a car does not rotate 180 on the grass at 15km/h. especially not a v8 supercar
https://www.sau.com.au/forums/topic/345986-iracing/page/2/#findComment-7491424
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
