Well,
Im tempted too - looks like there is an MX5 only class again so I just gotta get my ass into gear and get national licence and medical and Im done
http://wakefieldpark.com.au/images/stories...eries%20rd1.pdf
https://www.sau.com.au/forums/topic/346016-mra-first-round-2011-jan-30/
ryan if you mean the state sprints you better register asap. in another thread brian mentioned there are 130 registered for only 100 spots already.
register via here: http://www.supersprints.com.au/
  • 1 month later...
congrats to the SAU-ers who made it to the track.
Michelle, who won a 2 horse race. sounds easy but the lap times say every one was very close
Mark who came 3rd, 6th and 8th in a car he would not be familiar with, up against cars like a Mosler.
Chris who came in 4,3,4th in the MX5s
Most important thing we can be doing is be out there supporting the series so it can continue :D
well done guys
cheers duncan :)
and a PB for me too with a 1.14.1
I think you should get into this series too! some good cars and wide range!
I'll prob do a few super TT events now, looks fun
yeah Chris I would have been there for this had my car been running, and I intend to do a few rounds when I can.
My priroty is the CAMS state series but there are onyl 5 rounds these days (used to be up to 8), so I am looking forward to running smoe other events.
But more importantly, this is about the best series for a first time racer. The focus is on working together and fun, rather than the usual racing bullshit from the cams series.
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
