Hi guys,
Looking at upgrading the diff in my R32 GTST. Has an RB25DET fitted & has seen better days... Viscous LSD is still working fine (for now) but diff is very noisy (suspect c/w & pinion or carriers) so figure while I'm there I may as well upgrade LSD. Daily-driver but may end up doing track-work soon.
Basically tossing up between a full GTR rear-end & an aftermarket LSD centre. Roughly same sort of price...
I am a mechanic by trade & specialise in auto-transmissions & diffs, etc so could easily enough fit the Nismo clutch-pack upgrade to the GTR diff.
I realise the GTR shafts are stronger but car is & will be only making around 300rwkw so probably overkill.
Has anyone even had problems with GTST shafts before at any power level?
The thing is GTR shafts are also heavier & for the sake of performance, etc I am trying to keep everything as light as possible.
I know the GTR runs alloy hubs so would this counter-act the extra weight of the shafts?
Any opinions on the best overall compromise would be great.
Cheers
  • Nope 3
  • 1 month later...
The driveshaft in GTS-Ts have been known to wear over time, especially with highly modified gts-ts
The most common problem is tailshaft backlash which can come in the form of noise/vibration from the rear in a different degrees.
When I had my recent service, my mechanic said that I have a bit of tailshaft backlash present - still can't pick it myself but its there none the less.
With this wear starting to happen with mine, and me only only making 235rwkw, I'd say it would be a good idea to upgrade the diff if your making 300rwkw +
GTR diff will be bullet proof. Get a recon'd second hand one and you'll be laughing.
James
I snapped a rear axle with 195rwkw. But I think that was no real indication of the strength of the axle. Know plenty of other GTST's with more power or harsher drivetrains that have been fine I think I was just unlucky.
have you considered a 1.5 way? A friend went from a locked diff to a 1.5 way in a 32 and was very happy with it. seemed very predictible and locked hard (Nismo 1.5 way I think it was)
There not terribly cheap to buy outright but he got his second hand at a decent price so if your lucky something like that could show up, or you might find something on import monster or a japanese spares site. I dont know much about the GTR Diff's but I can tell you for sure that the axles are thicker and stronger. But I didnt really think at 300rwkw you would be snapping axles (despite me snapping one with 100kw less)
I have a Nismo 2-way in my 32gtst and I love it, was a daily driver like that for over a year. It's not for everybody though and requires a slightly different driving style.
If you like scaring grannies, mothers and small children in carparks, as well as having a SUPER predictable diff, then go the 2-way :P
Pretty much as bubba has stated.
For a daily i personally would not get a tight mechanical diff. I put a regular old nismo 1.5 way in mine, and though it did the job for the track and skidpan duties the car got, it made me dislike the car as a streeter. Nothing wrong with the diff, i still have it in my s13 track car.
For a streeter i'd get a nismo pro 1.5 way and adjust the preload to soft for daily duties. Plus there is always redline friction modifier to make it a bit nicer as well.
As for breaking drive shafts; If you drag it with sticky tyres you will break a drive shaft at some point. Upgrade to the gtr centre and shafts if that is the case.
Edited by badhairdave
this but get the pro tt model and leave the preload in the middle.
mine has seen 300rwkw for 2 years and never missed a beat. it's not a hastle for daily driving at all
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
