  On 21/10/2011 at 3:53 AM, R31Nismoid said:
:stupid:
124mph is what a full weight (1700kg+) R33 GTR will do with 330-350rwkw.
No way it was 500rwhp in a lighter body with 124mph
in america a dynojet the old one s like ours is standed...
if you run a dynodyamic like most of you guys it s not reliable (dyno will not read the same from shop to shop cause its adjustable)
and a dynopack is a hub dyno so it would read alot higher( also adjustable so its no consistance)
  • Replies 121
  On 21/10/2011 at 3:24 PM, SimonR32 said:
I must have taken the I'm with stupid the wrong way... Carry on :)
It's in my signature guys... I mean come on :whistling:
Oops I was on my phone again with no sigs.
Who cares what the power really is. The dyno is there for tuning and upgrade comparisons, so long as you are using the same dyno everytime then you can see what changes net the best results. Most dynos in this country are probably dyno dynamics (though I could be wrong, not really sure) and they wouldnt be out by too much more then say 5-10% from eachother. Which in the grand scheme of things isnt really that much.
I can comment on the methanol helping make power safely and easily. It is amazing stuff, you can be around 15% too rich and it doesnt affect power production, it just runs alot cooler, if you run it too lean, it wont knock, it just usually melts pistons pretty quick.
We pumped out 590rwhp on the rb30det w/gt35r last week. Boost bled from 23psi down to 19psi (running on gate pressure only, no controller). When we setup the solenoid and get it to flatline boost to redline I suspect the power will grow a little over the 600rwhp mark. Which is going out of the realm of regular gt35r territory by a long shot.
I dont know why alot of other people dont run it, or atleast run it in a mix w/ 98pulp. I just cant express enough how magical it is. The only negative is you need a smaller less efficient radiator and oil cooler. Not very often you go backwards when running a turbo car in those two areas lol.
there are heaps of people here that are making that power on stock rb25's
why are you not capable of understanding this?
did you look at the dyno thread like we told you?
also a dynapac hub dyno can read higher, or it can read the same as a dyno dynamics etc, as there is a correction mode for this.
(also my previous motor lasted 3 very hard years at that level, but did die eventually)
  On 21/10/2011 at 11:57 PM, zebra said:
Ye. They can last at over 400 for a while. But look at his many have broken at 300hp. Any number of things can go wrong
90% is bad tuning, or something breaking to cause the tune to go out, afm/fuel pump/injectors failing. If any of this goes at any power level it can kill a motor quite quickly.
My cousins bf ran his r33 with around 420rwhp on a stock internal rb25 for around a 1.5 yrs thrashing it at drift days before it blew. That was pretty good considering it did alot of street racing and skids also.
Yup I agree with you ....
  On 23/10/2011 at 4:58 AM, zebra said:
mmm..but if youre only running in the mid 120s then it isnt really making 500+ now is it
Exactly as we were saying :D
His "500rwhp" is like our 400rwhp - or there abouts.
So yes - in his terms 500rwhp is most certainly possible
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
