:stupid:
124mph is what a full weight (1700kg+) R33 GTR will do with 330-350rwkw.
No way it was 500rwhp in a lighter body with 124mph
in america a dynojet the old one s like ours is standed...
if you run a dynodyamic like most of you guys it s not reliable (dyno will not read the same from shop to shop cause its adjustable)
and a dynopack is a hub dyno so it would read alot higher( also adjustable so its no consistance)
  • Replies 121
Who cares what the power really is. The dyno is there for tuning and upgrade comparisons, so long as you are using the same dyno everytime then you can see what changes net the best results. Most dynos in this country are probably dyno dynamics (though I could be wrong, not really sure) and they wouldnt be out by too much more then say 5-10% from eachother. Which in the grand scheme of things isnt really that much.
I can comment on the methanol helping make power safely and easily. It is amazing stuff, you can be around 15% too rich and it doesnt affect power production, it just runs alot cooler, if you run it too lean, it wont knock, it just usually melts pistons pretty quick.
We pumped out 590rwhp on the rb30det w/gt35r last week. Boost bled from 23psi down to 19psi (running on gate pressure only, no controller). When we setup the solenoid and get it to flatline boost to redline I suspect the power will grow a little over the 600rwhp mark. Which is going out of the realm of regular gt35r territory by a long shot.
I dont know why alot of other people dont run it, or atleast run it in a mix w/ 98pulp. I just cant express enough how magical it is. The only negative is you need a smaller less efficient radiator and oil cooler. Not very often you go backwards when running a turbo car in those two areas lol.
there are heaps of people here that are making that power on stock rb25's
why are you not capable of understanding this?
did you look at the dyno thread like we told you?
also a dynapac hub dyno can read higher, or it can read the same as a dyno dynamics etc, as there is a correction mode for this.
(also my previous motor lasted 3 very hard years at that level, but did die eventually)
Ye. They can last at over 400 for a while. But look at his many have broken at 300hp. Any number of things can go wrong
90% is bad tuning, or something breaking to cause the tune to go out, afm/fuel pump/injectors failing. If any of this goes at any power level it can kill a motor quite quickly.
My cousins bf ran his r33 with around 420rwhp on a stock internal rb25 for around a 1.5 yrs thrashing it at drift days before it blew. That was pretty good considering it did alot of street racing and skids also.
mmm..but if youre only running in the mid 120s then it isnt really making 500+ now is it
Exactly as we were saying :D
His "500rwhp" is like our 400rwhp - or there abouts.
So yes - in his terms 500rwhp is most certainly possible
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
