PM or call 0423 799 320 with any questions. Everything is ONO
RB25 Cam Covers $50 for the pair
RB25 Timing Belt Cover $25
33 Side Exit Exhaust (Great for track days) $100
High Mount Dump Pipe $50
Cam Angle Sensor $25
Malpassi Fuel Reg $40
38mm Dual Port Turbosmart BOV $150
Indicator and Wiper stalks $20 a side
33 Front Strut Brace $40
33 Radiator Air Guide $30
Cusco brake cylinder stopper $40
https://www.sau.com.au/forums/topic/346064-wrecking-r33-rb25-parts-cheap/
Clutch Fan $50
SAAS Racing Seat $125
RPM Racing Harness $50
Rear Tailights $100 for the pair
Front Guards $100 each
Boot $75
Rear Brake Calipers $100 for the pair
Hand Brake cables $75
Almost new Pineapple Bushes $50
New Alternator $100
RB25 Throttle body $50
Also have heaps of interior bits and pieces
Will send PM - shotgun strut brace and fan if its in good nic...also do you have dash/cluster surround trim and handbrake/gearlever boots?
Does the fan have any cracks around the circular part in the middle (or anyewhere)?
Edit - Or not, PM inbox full :D
Edited by Pope
Edit - Or not, PM inbox full :P
Fan has no cracks from what I have seen and both my and my mate have had a look, and I do have the dash cluster trim but not the handbrake or gearlover boots..
Edited by TJ_R33
Ok sweet, will grab that as well, can you PM a mobile or email? Should be able to come pick them up. Strut brace mine?
Number is at the top of the page mate, when did you want to pick them up?
Sorry, reading fail - looked at bottom of post not top :P Just tired now, will try again tomorrow at a decent time :blink:
Probably on the weekend if I can, not sure which day ATM, can prolly do either. Don't suppose you have an old radiator lieing around...mine blew on way to work today ;)
Sorry, reading fail - looked at bottom of post not top :) Just tired now, will try again tomorrow at a decent time :)
Probably on the weekend if I can, not sure which day ATM, can prolly do either. Don't suppose you have an old radiator lieing around...mine blew on way to work today :(
I might still have my old one somewhere, I will have a look. I must have already sold the strut brace a few months ago mate cause I had a look for it tonight and couldnt find it, I could have sworn I say it the other day.
  • 3 months later...
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
