I have found it to cost about the same as 98 once the lower price is taken into account. Caltex sell their E-Flex for 20c less than unleaded. Cheapest power upgrade I have done as I already had the supporting mods.
A Walbro pump and seimens deka injectors (for the neo motors) wont set you back more than $600 but you will need some way tuning it.
The ethanol will strip clean the fuel system so you would need to change the filter after the first few tanks. Ive been running it for 8 months now with no issues with the stock fuel system.
what are you using to account for the variations in ethanol %?
i was reading it can fluctuate anywhere from 50% to 85% hence there being e-flex and e85
Thanks Brendan, but I'm north and it's not worth going all that way just to run the tank empty by the time I get home :P
According to the Caltex web site Salisbury Park and St Marys stock eflex too, but I guess its a practical thing - whats the point in running eflex if it's that hard to get?
I have two Caltex servos conveniently close to me... is it that hard to put an eflex pump in?
I'm guessing Liberty have their own fuel supplies, and it seems they don't have 100 octane, highest is 98.
They told me late June/July they should be replenished. Fingers crossed!
  • 1 month later...
my dad works @ birkenhead Mobil and said libery 98 used to be mobil 8000 and now shell won the contract to supply 98 ron fuel to liberty
and to everyone surprise guess what shell and mobil share the same holding tanks its the same fuel, he said when shell take theirs out they add additives for Vpower
EDIT
sorry its united
Hi all,
I am at athelstone, SA.
Any info on when/if they will be re-selling E10 100 octane?
Surprised at the advice that they can't get the ethanol, as Liberty are still selling the 94 octane E10 unleaded.
Cheers,
Adrian
E10 100oct is now back in stock at United servo pooraka. Been waiting a couple months for it. I'm running it in our M35 and now I can use high boost setting in my 180sx now that it's back.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
