Item:
1 - Series 2 Rb25det Yellow Jacket Coil packs
2 - Dakota Digital Tachometer Signal Interface
3 - Dakota Digital Speedometer Signal Interface
4 - S15 Gauge Cluster
5 - Stock Series 2 RB25det ECU
6 - Trust / Greddy Emanage Blue
7 - Autogauge 270 Stepper Motor 52mm Boost
8 - Autogauge 270 Stepper Motor 60mm Water Temp
9 - Autogauge 270 Stepper Motor 60mm Oil Temp
10 - Autogauge 270 Stepper Motor 60mm Oil Pressure
Brisbane West
Website:
SD / SAU
Item Condition:
1 - Basically Brand new out of box, used for total 30-60minutes if that... These are $400 posted.
2 - Brand new out of the box, modifies stock signal and corrects to read properly on dash > more info < These sell for $80usd which is $83-85 USD minus Post
3 - Brand new out of the box, modifies stock signal and corrects to read properly on dash > more info < These sell for $80usd which is $83-85 USD minus Post
4. Excellent Condition, for memory 70-80,000 km on the clock, its a manual
5. Series 2 rb25det Standard ECU
6. Universal Emanage Blue w. Ignition / Injection Harness, USB, software on a CD (latest version etc)
7. 52mm Boost w. Power Lead, Sender / Sensor. Dint in surround, asif you'd notice it. These sell for $100. Sell mounted to top of s13 column trim or by itself.
8. Brand new out of Box (still has protective film) 60mm Water temp w. Power Lead, Sender / Sensor. Sell inside s15 dash vent or on its own (modified to fit inside s15 dash vent cup, so it has the silver trim around, looks better then most s15 gauge dash conversion) These Sell for $100 SEE PRICE FOR DETAILS
9. Brand new out of Box (still has protective film) 60mm Oil Temp w. Power Lead, Sender / Sensor. Sell inside s15 dash vent or on its own (modified to fit inside s15 dash vent cup, so it has the silver trim around, looks better then most s15 gauge dash conversion) SEE PRICE FOR DETAILS These Sell for $100
10. Brand new out of Box (still has protective film) 60mm Oil Pressure w. Power Lead, Sender / Sensor. Sell inside s15 dash vent or on its own (modified to fit inside s15 dash vent cup, so it has the silver trim around, looks better then most s15 gauge dash conversion) SEE PRICE FOR DETAILS These Sell for $150
Reason for Selling:
Fix motor
Price and Payment Conditions:
1 - $350
2 - $80
3 - $80
4 - $120
5 - $100
6 - $300
7 - On S13 Column Trim $60 with trade for stock trim ..... Or on its own $70
8 - For S15 Dash $70 with trade for stock air vent ..... Or on its own $80
9 - For S15 Dash $70 with trade for stock air vent ..... Or on its own $80
10 - For S15 Dash $120 with trade for stock air vent ..... Or on its own $130
Extra Info:
All electronic items i can help wire into your car or assist you.
Pictures:
2/3 - th_30112010456.jpg
8/9/10 - th_30112010461.jpg
Contact Details:
Call or SMS - 0420 855 181 Email or Msn - [email protected] and of course feel free to PM
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
