you may find that it starts to ping up in the rev range as it will be leaning out.
only way to tell for sure though is to put it on the dyno. a dying fuel pump will generally have ok AFR's down low but the further up the rev range you get the leaner it gets because the pump will be maxing out and can't flow any more fuel. if the AFR stays the same all the way through the rev range, or gets richer up top then the pump is ok.
ok, does consult show afrs? or needs dyno?
will i hear pingning if it is pinging? i remember in my old vh u could hear loud pining when it did it
Edited by Clutch
The only way to read AFRs is with a wideband oxy sensor either on street or dyno.
But come to think of it, some of the laptop programs may be able to show your AFR if hooked up to a wideband as well.
Yeah you'll need the wideband sensor, I think Bosch ones are around $100? You'd still need software which usually needs to be calibrated to the sensor. Even the LM has a calibration, although pretty easy to work with.
One run on a dyno and they'll give you an accurate AFR, they can do a flow test while under load, and might even find other issues you didn't even know about. :P
My Stato pump died recently, I jumpered the relay and got under it, accidentally bumping the fuel tank, and it started again. Turns out they often have a crap connection in the tank. Good too, because I despise working on fuel tanks.
Edit: And with audible pinging, aint that pretty high on the 'ping' scale?
Edited by GTRPowa
when i had my car on the dyno last, was a while ago now. the dude richened up the afr's in the high rpms, on the first couple of runs, to make sure it wasnt struggling to supply fuel.
i guess that's how they test your pump?
shouldn't need much more than getting a few power runs done. you have stock ecu don't you? if so then they can't alter the AFR's to see what sort of headroom you have above what it is running.
you could also try bumping the boost up a bit from what you have it at, as it will be using a bit more fuel that way so if it is fine on the higher boost then it will be fine on what you are running.
agreed
i can up the boost but it goes way to R&R in midrange, but i guess that means the fuel pump is ok??? after mid range it speeds up a fair bit, would that mean that the higher rpm at higher boost is leaning out?
no, R&R doesn't stay the whole way through the rev range, it only stays like that for where the ecu is seeing too much airflow and throwing a tantrum. generally it will always come good in the upper rpm.
ok good, so it would seem my pump is ok then
sweet
was stressing that my pump would die halfway to philip island and id be farked.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
