Hey all,
I've searched the forums a bit and found that people are saying that it's hard to get an acccurate reading using a timing light on an r33 gtst!
I checked my base timing by using my timing light I have and found that it was showing 6 white marks past the orange one.
Does this really mean that my car's timing is advanced 30 degrees??? cos I've heard that timing is hard to check with a normal timing light on an r33 and that the readings that you get are double what it actually is???
That would mean my timing is 15 degrees which is correct. The car has been running for months and i've never had a problem on this timing setting so I have a feeling that it prob is actually 15 degrees. To be safe for the time being, my tuner retarded it, but that has robbed me of precious power and I think that the readings we are getting are wrong.
Can someone please help and shed some light on this!!!!
How can I get an accurate reading of my base timing???? I'm happy to take it somewhere and pay for them to check it if I have to!!
I need urgent help.
thanks
Hi Black 33,
First Qion what/how are you hooking the timing light up to read the ign puse ? As there are a couple ways of doing it !
I'm would be happy to help you in this matter in return for your vin number so my mate can get a water pump for his ser 2 RB25 in a R31 as we might of found today that the blocks are diff between ser 1 and 2
mincus
Well I am having a timing problem on my Series II motor. Mine always reads far advanced like 30 degree's. When I first got my car running I had the sensor almost fully advanced and it red 15 degreee's Car ran great! Then after a few days the car started to run slugish. I checked the timing and it was off the scale. I set it back to 15 degrees again. Now the sensor is in the middle of the range. When I set it to read 15 degrees the car runs very slow. With it set farther ahead it runs better. I turned my boost up to 10 psi (Everything stock except 3" turbo-back and HKS SSQ BOV) My car shoots flames between shifts. Is this nomral? I guess a S-AFC is needed?
two places to take timing from on series 1 (that I know of).
1. there is a loop on the back of the ignighter - this will give you double the actual timing, so if you see 30deg on the engine, its acutally 15 deg.
2. remove the cover off the coil packs, and take the signals from number 1 - this will give you the actual timing. A bit more accurate than method 1.
not sure if it is the same for series 2, but you can guarantee if you take the signal from no 1 coil pack it will be accurate.
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
