I have searched, and found plenty of posts saying to cut the Yellow wire #53... But have not found one saying anyone has actually done it and it has worked, with no side effects, it is an R32 GTR, so no Auto, and Hicas has been removed, so no problems there. I am competing on Saturday at Mount Panorama, so if I cut the yellow wire, will it remove the limiter and ensure everything else operates as per usual, thanks!
https://www.sau.com.au/forums/topic/346144-r32-speed-limiter/
i could be wrong but i think that cutting the speed sensor wire to the ecu isn't 100% without side effects. i'm not sure about the skylines, but i think some cars have slight mapping tweaks for different speeds. i'm honestly not sure though. i just remember hearing a tuner talking to someone about speed load settings. i could be imagining things tho.
if your going to use it for motorsport, why not just purchase yourself a nice haltech ecu and be done wiht it, or even the power fc from memory can remove of it. if all that dont work, get a SLD or so called speed limit defender, there are heaps available for the r32gtr's. and cost about 140-200 bucks.
here is one:
http://cgi.ebay.com.au/HKS-SPEED-LIMIT-DEF...=item4154ada711
Edited by Bronx
Need this done by Saturday for minimal if not $0, I have an ECU there that will remove it which I have been trying to get into a dyno snd tuned, but with finding out yesterday I had a blocked radiator and possibly stuffed thermostat, any ECU options are out the window, hence cutting wires... Would love to hear from someone who has done this...
Well worst that could happen is that the car didn't work, and I could solder the wire back together, so I cut it.. For anyone needing/wanting to remove the speed limiter for motorsport use, simply cut the yellow wire, (#53, go down the left hand set of pins from the bolt hole, there are 2 sections, the third from the top of the bottom section is 53, or just search google for the pin outs) and the speed limiter will be disabled, I have had no adverse effects (I have no Hicas already) but do it at your own risk.
I have heard that it messes with the hicas, because what you have done is cut the speed sensor wire to the ecu. So the ecu doesnt know what speed you doing. Steering wheel hasnt felt heavier? (someone clarify this)
actually the worse that could happen would be that the car wouldn't be using the appropriate mapping and run lean and damage the engine.
You are one of the people on here I would have listened to Marc, but varying mix based on speed makes no sense at all for a few reasons... My car has Hicas disabled so could not have effected Hicas,
Found this out the hard way at least 15 years back, the ecu needs speed input.
The car would go fine one day, sluggish the next with no obvious reasons.
Connect the speed signal, reset ecu and all fixed.
Martin Donnon who is pretty switched onto ecu's also found out the hard way,
An old Zoom write up>>
ok so i rang my tuner mate to ask him. he said that as far as he is aware the stock ecu has 3 maps. there is the idle map, a transition map and the full map. the idle map is what is used when the car is in neutral. when you put it into gear the car registers that it's in gear via the neutral switch in the gearbox (this is why autos than have been converted to manual can make less power than a proper manual since they make the computer think it's in neutral all the time - since the autos will only start in park or neutral - so are stuck on the idle map). the transition map is similar to the full map but not as much timing as well as a few other things different. the full map is activated by the VSS (vehicle speed sensor). the old memory is getting a little bit fuzzy at this point, but i'm pretty sure i have this the right way round. the full map also has things like your closed loop o2 sensor feedback as well as fuel cut on deceleration.
to sum that up a bit, my mate said that power wise it will be stuff all difference in power between the transition map and the full map, but he also said to stop being a tight-arse and do it properly, LOL. he said to either go a VSM, speed cut defender or the best option is to go an aftermarket ecu, even if it's only a nistune.
Awaiting delivery of PFC, was only a stop gap because of radiator issues stopping it from making the Dyno, end of the day though an ecu sees the air going through the AFMs and the amount of fuel coming out of the chambers and adjusts on that. Road speed cannot really be used as an accurate variable because 100k with a 20k head wind or 20k tail wind gives you a massive difference in air coming in, hence AFMs.. In 2 weeks it will be trivial anyway
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
