Ummmmmmmmm
Genuine Works VS-TX 19x9+37 (front) 19x10+36 (rear) No tyres.
I bought these new from japan around 12 months ago so i also have the Work boxes they came in.
They are in "as new condition" (as the pics indicate)
****ASKING $3,100****
These are the latest VS design in the Work range & they have the Work serial number plated on the outer edge of each rim.
Beautifull rims with very nice dish on the rear!
These will clear big brakes on the front so brembos,alcons,surpa brakes etc fit behind these nicely.
I had them on my soarer and what an improvment they made made to the looks.
As stated in the title,will fit Most skylines including r32,r33,r34,v35.Soarer,supra,aristo and what eva else these offsets fit....
NEW PRICE FOR EACH RIM IS $1390X4=$5560 SO PLZ KEEP ANY NEGATIVE COMMENTS TO YOURSELF!
I can ship Australia wide via courier @ your expence (around $100-$120 Australia wide) or u can pick up in southside Brisbane.
Prefer phone enquiries rather than pm's !!
PLENTY OF PICS ATTACHED SO U CAN SEE EM FROM EVERY ANGLE.
PHONE-0414-729-004
  • Replies 40
Have a look at these...great looking wheels and only $2600+ postage Australia wide which wouldnt be any more than $120????
Cheepiest 19inch Works that look as good as this..
0414-729-004
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
