Got a R34 with a carbon fiber bonnet and the car was yellowed because of the bonnet and ride height less than 100mm.
I am planning to unbolt the side skirts and front lip which will sort out the height issue and go to the pits with the bonnet and ask if I can get a permit for it.
I was told the bonnets are illegal for cars produced after 1996. I don't know how true this is but I was hoping someone would have an idea?
https://www.sau.com.au/forums/topic/346175-r34-carbon-fiber-bonnet/
As per post above ^ they are not legal and you will not get a permit for it. To my knowledge the only 'legal' carbon fibre/fibreglass bonnets are those sold by Blits Australia (not to be confused with Blitz) which are ADR approved, if they are not ADR approved (the majority of them) then they are not legal and there are a million threads as to why;
Do not close properly, hinges etc causing danger if the bonnet lifts and shatters into your windscreen - can get bonnet pins to combat this problem but still illegal.
Also have read that these can be dangerous in a crash, rather than crumpling like metal they 'shatter' supposedly..
Sucks balls coz i really want an aftermarket bonnet but cbf with the problems associated with having one, good luck.
Sorry if this hijack your original post, Salah.
I just want to know if there are any shops in Perth that are representative to Blits Australia.
Thanks in advance, guys.
Edited by Victor.T
There are no ADR approved aftermarket carbon fibre bonnets. As Jason said, only way it is legal is if it came like that from factory.
Reason they are legal from factory and not aftermarket is simple, your bonnet is part of the crumple zone on your car. Changing the factory item affects how the maker intended your car to behave in a crash and hence makes it unsafe.
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
