Got a R34 with a carbon fiber bonnet and the car was yellowed because of the bonnet and ride height less than 100mm.
I am planning to unbolt the side skirts and front lip which will sort out the height issue and go to the pits with the bonnet and ask if I can get a permit for it.
I was told the bonnets are illegal for cars produced after 1996. I don't know how true this is but I was hoping someone would have an idea?
https://www.sau.com.au/forums/topic/346175-r34-carbon-fiber-bonnet/
As per post above ^ they are not legal and you will not get a permit for it. To my knowledge the only 'legal' carbon fibre/fibreglass bonnets are those sold by Blits Australia (not to be confused with Blitz) which are ADR approved, if they are not ADR approved (the majority of them) then they are not legal and there are a million threads as to why;
Do not close properly, hinges etc causing danger if the bonnet lifts and shatters into your windscreen - can get bonnet pins to combat this problem but still illegal.
Also have read that these can be dangerous in a crash, rather than crumpling like metal they 'shatter' supposedly..
Sucks balls coz i really want an aftermarket bonnet but cbf with the problems associated with having one, good luck.
Sorry if this hijack your original post, Salah.
I just want to know if there are any shops in Perth that are representative to Blits Australia.
Thanks in advance, guys.
Edited by Victor.T
There are no ADR approved aftermarket carbon fibre bonnets. As Jason said, only way it is legal is if it came like that from factory.
Reason they are legal from factory and not aftermarket is simple, your bonnet is part of the crumple zone on your car. Changing the factory item affects how the maker intended your car to behave in a crash and hence makes it unsafe.
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
