Im just about to drop in some tomei poncams 8.5mm lift into my rb25det and was contemplating doing the valve springs while ive already taken the cams out.
I was looking at the tomei type a valve springs 8.8mm lift , are these the correct ones I need?
http://cgi.ebay.com.au/Tomei-Valve-Springs...31#ht_500wt_715
https://www.sau.com.au/forums/topic/346182-valve-spring-choice-for-rb25det/
Yep get Performance Springs.
I got a set in mine and they were a great price :blink:
You taking the head off to do the springs? (I did)
I looked on there site , which ones do I need cause its not model specific? and no Im going to do it with the head on and just pressurize the cylinder to hold them up.
The Performance springs is just little bit stronger then standard. The supertech springs are probably the best you can get at this stage. Those are stronger then the type B Tomei springs which are cheaper as well.
Totally agree. I lost one engine and broke valve springs in another with performance springs. If your aim is big hp the supertech is a much better option.
He is only after a 280-300rwkw setup it think so not huge HP/Boost given a stocker motor.
You're probably right Ash. they are an upgrade but if big hp is the goal I would choose other brands.
I am not the only one i know of to have probs with those springs in high hp situ's.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
