EMS stinger FTW!!
Lol :D
i like the motorsport ones, actually also good ecu's just did a 300rwkw CA with one, had nice timing control... no drift at all was impressed with it.
  • Replies 40
ive ran wolfs on all of my cars s14, r32 gtr and got one going in my r34 in january....
they r a good ecu, all of my mates use them 2, from 200kw s13's to a 800hp rx4 drag car....
its all in the tuner, if ur in melbourne take it to robert sabadin in clayton.
i used the v4 in the gtr and 2hunge and it was sweet, the new version v500 hasd ironed out the lil head f**k of cold starts and are very good imo, however as stated there only as good as there tuner. if u contact wolf directly they will tell u there prefered tuner in ur state...
yeah i send any WOLF enquiry to Rob @ sabbadin, he is the only decent Wolf tuner around i can trust to send people too..
He loves his wolfs, he couldn't understand why I wanted to get rid of mine and replace it with a stock ecu with a nistune. The fact it needed 1100rpm to hold idle, 19L/100km and it doesn't look stock were pretty good reasons to me.
did u have the plug and play or the full ecu swap.
the plug and play is pretty subtle and easily hideable.... the full swap is another story though lol....
there new hand controllers and dash displays are pretty cool too, a little pricey but i really like them
did rob or matt tune ur one dude or did u get it done somewhere else??
it was plug and play, rob tuned it but I am in SA so I flew over to buy the car, I generally just wasn't happy with the feature set or performance of the ECU, poor idle, poor fuel economy even with a solid tune on it, there was many hours spent on the dyno with the previous owner.
I went back to the rb20 ecu with a nistune and in just 3 hours had it beating the wolf in every department, with a road tune and a few more hours touch ups it is brilliant now, the wolf could never match its fuel economy, idle, or being able to handle air con on at the same time, even the AAC valve control was crap.
not to mention instant defect if seen by a police man.
this is why most tuners CBF'd with them..... good tunes are possible but you need to spend too much time compared to just about every other ecu out there, it doesnt make good business sense.
Wow I really didn't think they where that complicated?
Especially the V500. We have used them on a few cars for there PWM output control.
I tune every system, but when you require a system (at a reasonable price) that can do pulse width modulated control over TPS, Wheel speed, Boost, RPM and engine temp all at the same time? The answers are very far and few between. Even the latest offering from haltech cant. Please correct me if I am wrong but I couldn't see anything on Vipec either. Again correct me if I am wrong but there may be a 32x32 table in EMS that can be PWM, but I think its just a 3D table, with no external corrections.
Just to give you an example, Boost control. Easiest PWM to understand.
What may be required is a boost pressure of 30psi. But when on the trans brake boost needs to be limited to 10psi. Also from 0 - 40 Kmph boost needs to be trimmed from 10-25 then from 40-80 the boost trimmed from 25-30. Now I dont mean trimmed as in stepped, I mean trimmed. So when running High horse power engines on tiny little radial tiers we don't shock them.
I also want the boost to be trimmed from 0deg engine temp to operating temp. So gate pressure at 0 deg and 30 psi from 64deg and up. Even run an external switch for your 2 maps, one for 98 and one for E85. So when we are on 98 our base pressure is now 20psi and all other corrections work from that.
Sounds easy, Most systems cant do it. Or they can do just that and nothing else.
I honestly don't think it takes me any longer to tune a wolf than any other system, be it adaptronic or power FC or a VE SS commodore (HP) with a massive cam shaft.
Edited by HYPED6
that's about 30mins work max... you telling me you can do the above in 30mins on a new engine from scratch..... as for e85 just run the one map and depending on ecu use the wide band input to auto calculate (like gm e38 in later holdens) or a content sender.
I think you missed the point. Its not a description on how fast I can tune. Its to show that the days of "tuning" to 12:1 and putting in the correct timing at full throttle are now gone.
Its the extra things like autronics awesome individual cylinder trims over load and RPM. Very useful when pushing an engine and you have 1 pesky cylinder that is just too hot. You trim it up and keep going. Great for the tuner that monitors individual cylinders. While every one else leaves it at 0 and wonders why you would ever need them.
Its EMS's Injection end angle over Load and RPM. This is awesome when you have 1600cc injectors and are only using 50% duty on 98 at full noise.
Its controlling automatic transmissions. And not in preset little boxes like 3-4 shift pressure but actually wiring a system that takes control of the auto.
Its the 2 steps with no external buttons. Just clutch in, full throttle and 0 wheel speed.
Its Nos control PWM. Use a solenoid that can flow 400hp worth of gas and trim it over wheel speed. Dry shot with all the trimming done by the ECU
Tuning engines for turbo preservation. Measuring the air in and the air out. Pressures, Temps all the fun stuff.
Tuning for engine preservation, Holding an engine flat for an hour, not just a power run or drag run. Its squeezing 800rwhp out of a stock bottom end 2.5 liter engine by measuring and calculating.
This is what I am demonstrating. Not how long it takes to trim a PE table and throw some timing at an engine.
^^ Thats all very well...but that would be what 0.5% of ECU's would need those functions.
So what car needs 11ty funtions like a staged 400hp N2O setup, or 20 different boost levels?
The average club level circuit car....nup
Street/Strip.....nup
Pure street....nup
Race boats....nup
Champ car/ALMS prototypes...maybe....but how many of those use Wolf?
This is why the cheaper ECU's eg Haltech, Link, EMS, AEM etc etc dont have these features.
I would rather have an ECU that can pick up the factory crank trigger over somthing that has a million features but struggles with the Nissan Optical Se./nsor.
Sure If I were building a mega budget endurance racer so I could win Le Mans than sure I would want those features.....but would I pick Wolf over a Pectrel T-6, Motec M800 etc.....Well no.
Pure street....nup
Race boats....nup
+1
once again again proving race car examples have little to no bearing on 99% of this forum.
long lists of features are wants, not a need.
That wasnt my point, you said it takes no longer tune than other ecu's and used GM reflashing as an example which takes very little time to get perfect due to the complex background algorithms.
there is room for all ecu's, everyone has their favorites and i have about 4 i really like and one i cant stand.... at the end of the day it just personal preference... it just turns out many i speak to in the trade and @ seminars share the same sentiments.
Pure street....nup
Race boats....nup
I am by no means defending wolf. When you start to see what is involved in setting up these cars on a daily basis, I would rather have the option and not use it than need the option and not have it. Be it a haltch/motec what ever.
The average club level circuit car.... Last targa I tuned a 280Z that cam 1st in its class. No bells and whistles necessary. So yes No 400 hp gas here. Just simple Electric Water pump and fan control
Street/Strip..... The quickest 1JZ in Australia was set up with the exact boost control setup in my post.
Pure street.... Cant go past the factory systems, bar none.
Race boats.... When you are holding an engine flat for the southern 80 you better hope you have cylinder trim.
I thought on this forum there where enthusiasts from all walks of life. People that use there skylines daily, to the guys the just love trying something new and maybe drive there cars for half the year.
I am an enthusiast just like you guys. I see this stuff every day. I like you guys am always looking for better ways to enjoy my passion which is cars.
If you are some one that just needs your management system to control injectors and coils then thats great. Believe me. I have done more than 1 nistune in my time. But engine management doesn't just stop there.
Edited by HYPED6
Even a 15 year old PFC have cylinder trims, not many ECUs I know Dont have it.
Shanes 1.5JZ is hardly a street strip car either.
I dont hate wolf, the Soarer guys love them (but most of them are clueless lol) But there are better options out there imo. features or no features.
We are, and the OP is talking about a daily driver with basic mods.
Hence the ECU he's asking about realistically isnt the best choice.
So looking at this from a layman's point of view I can only draw one conclusion, The wolf is all that and more but a lot of tuners are shit scared of them through ignorace.
I'm glad I let my tuner talk me in to one. It shits on the previous haltech i was using. And funnily enough, My car spends less time on the dyno for a tune than ever it did with the haltech and for a better result.
Who's fault is that, The tuner or the ecu ?
PFC Wont do it over load and RPM where you need them
Shanes Isn't the Quickest 1JZ. He has a 1.5. Derek Johnson has the quickest in his VS ute. And its a stocker bottom end still and very street driven.
For a Stocker RB25 I agree there are better options.
Edited by HYPED6
+1
yeah it has all the features but my point has been all along so many other ecu's have exact same features (and more) that take less time to navigate and in my own cars i have had many firmware and trigger issues. So basically why pay more for a product that is going to take you longer to get to point b? in a basic car with basic mods?? all those extra features can be a hinderance.
In a car like Hyped6 is talking about i can whole heartedly concur in needing all the extra bells and whistles and the added charge time to the customer to set up the boost vs gear... etc.. we have done similar with M800's and Link G4's. We hope to do some pretty crazy stuff with the new E1280s too but i would never recomend these ecus for a daily driver who has basic mods.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
