Geez where to start.
Been in the process of modding my car and have just got it back all good to go. Just a little bit upset that the car only made 290rwhp on 16psi. Here is the list of mods on the car currently.
Car is a 87 VL Calais with rb25det
Arias Pistons 20 thou over and rods
ACL Main Bearings, head and main studs.
Cometic Head Gasket
Standard Head for now
Greddy Copy Manifold and 80mm throttle body
Sard 550cc injectors
Bosch 044, surge tank and new lift pump
FMIC
Z32 AFM
R34 OP6 Hypergear Standard Hi-flow Turbo
Power FC and AVCR
that is all the engine mods, i have also upgraded the brakes, axles and added an lsd.
Car made 260 on 14psi (low boost) and 290 on 16 psi (high boost). only think i can think to do is set high boost to 18psi and see what figures i pull. do you guys think that figures seems a bit low considering the mods i have.
sorry guys, car is manual, 3inch mandrel bent exhaust from turbo back and just stock vl diff gears. i was thinknig the diff gears might have a bit to do with it as it sits at no more then 2000 rpm when in 5th going 100k.
Diff gears have no effect on power output.
so 290 is about 215rwkw and realistically 240ish should be achievable so what comp pistons, HG thickness and was the pfc tuned via knock monitoring or just the handset??
Well if pistons and head gaskets have dropped the engine compression then you will need more boost to make the same amount of power.
Make sure you have a 3inch metal intake pipe and a free flow exhaust. Try a run with dropped exhaust, high power gain means restrictive exhaust.
Also highly recommend a high pressure actuator if you are running a stock actuator. This turbo is capable of doing around 260rwkws.
hey guys i now have dyno print out up. i drove the car before it was tuned and the turbo kicked in alot harder then.
You will need a high pressure actuator to hold boost up top. Should have no issues getting 260rwkws. are you running stock intake pipe?
the guy that tuned my car took the actuator you supplied off and put a stock one on. he said it was jammed or something cause he didnt know when it was gonna open. im not sure what you mean by stock intake pipe, i have the normal exhaust manifold. here is a pic of my engine bay b4 injectors were fitted.
Edited by chrislesnar
The the whole reason of having an high pressure actuator is to hold boost. Put it back the way it was, and go for another tune. I really don't like people tempering with the actuator as most people lefts them un-adjusted. it opens around 18~20psi without boost controller. It is not Jammed.
Intake pipe is the pipe that connects the turbo to the pod filter, it needs to be an hard pipe at least 3inch in length. If the turbo can not suck in or dispatch air then it will result in lag and lose in power.
I can see a metal intake in there, so that issue is resolved.
Stao, the graph shows he is running roughly 1 bar at a minimum. Do you expect this result from the turbo in question at that boost level?
I think the result is more consistent with a stock op6 @ 14psi than it is a highflow with that sort of power. Someone correct me if I am wrong.
Yes, we had a chat today. I did advise before hand that i only wanted 16psi but i thought it would have pulled a bigger figure on that. I mentioned adding a high pressure actuator but he said that the 18psi actuator on it initially was to large and a 12-14psi actuator would be better suited for my build. Atm i happy with how the car is running but just think it could have pulled a larger figure. Will this high pressure actuator increase the hp by that much?
You have a built motor, it can take 20psi all day everyday without issue if it was built and tuned properly
even a stock motor will hold together with 18psi with that turbo, was there another reason they said that?
running it at 18-20psi will make a large difference to power.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
    • 75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive.
    • Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
