sorry for the dampener of mood this month, i guess life is like that at times. cheers for your thoughts tho, much appreciated.
barraspalding, how do you fit presents under that tree? :P
my son wanted a mini xmas tree this year, I couldnt find one for him anywhere tho :/
i was paying a parking fine when you must have gotten this photo.
oh, unlucky! sorry it aint the best shot, the background was a little bright and i was on my way to picking up more work.
havent done much with the camera lately with xmas and me being a bit slack, lol.
heres a few tho...
xmas eve and the xmas spirit is ready for a big day :P
the day after xmas, haha!
was looking for a drill bit in the shed and found this rusty old banger. knew i had to take a pic of it when i saw the number embossed on it.
first time taking panning shots of cars since selling the DSLR gear. the light weight of the P&S is a bit of a disadvantage, but managed to get this one at 1/50th of an old fella enjoying his pride and joy
Edited by Jay019
Nothing special, just a shot after my GTR's first wash (picked it up yesterday)...
Loving the 5D2 + Sigma 50mm f/1.4 combination, focus is a bit off sometimes, should probably micro-adjust it >_<
The mrs was givin that one by her work... it did have lots of scratchies hanging from it. Was told newsagencies sell em'
Love the spade bit shot, Jay. The aerial on the roof of the ute makes it look like it has an erection :/
i had to convert the shot of the drill bit to black and white tho cause i couldnt get colors to look right. the light i was using was a fluro with a very pink cast and i was too lazy to set my own K level. i really should have shot it in RAW and fixed it while converting it, but yeah not really how i roll with the point and shoot :P
as for the ute erection, bwhahahaha. i would have put it in the tray or something myself.
ah nice, will have to keep my eyes open for next year. win anything?
been a while since ive been able to get out and shoot at night, but got desperate trying to get a pic for my 365 day project...
yesterday was cool, was watching my little boy riding his bike and got a quick snap of him. he loves that bike and wants to ride it every day. so glad i thought to buy it for him. the three wheeler it replaced was awful, the cranks were so short that he couldnt pedal it at all, only push it along. this one he can pedal and get up a little bit of speed on too.
I mentioned before that I spent December moving into a new house which has been eating up all my time. My only camera time was a half hour walk around the block. Still busy but I things are settling down so expect me at whorey best in the Jan thread ;)
Dude, more shots of that little man-made lake/recreational area at the front entrance to your estate should prove quite fruitful!
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
