To much localised load being put on that lower pin. It will break the alloy casting.
You need to utilise the original holes and use the original counter bore to locate the component.
I tried that method years ago and broke every upright I did it to
Free advise. Do with it as you wish.
The upper and lower pivots need to be double sheer. The way I do the lowers is to machine an inverted _|_|_ shaped adaptor with a spherical ledge that locates into the original ball joint counter bore.
The edges are drilled to suit the old bolt holes and they are machine with a gusset on the front & back edges the radius' of the corners is very important to strength. I use a 1/2inch aurora rod end mounted vertically with a through bolt and have the lower control arm coming from there.
Do the exact same thing for the inner using the original 4 captive nuts.
For the upper outter I do the following
A similar |_| shaped adaptor with a pin machined from the billet that matches the taper of the upright.
Again it's double sheer and the rod end is mounted vertically with a through bolt.
For the upper inners a [ bracket can be machined and attached to the chassis however you intend to do it (this is the big time and R&D part of my setups that I won't give out)
Again double sheer and a through bolt.
Your method mounts the rod ends horizontally which limits travel and single sheer which loads the pins. The upright is also not strong enough to take the load the pin puts on it when you lower the control arm increasing the leverage ratio.
The upper would be okay the way you've done it but a horizontal rod end is frowned upon.
I'd recommend whoever is doing this have a read of Carroll smiths book "engineered to win"
It's old but Carroll was a legend of race chassis design, everything he ever wrote still rings true today
Much appreciate for the info Brad.
The component used in this conversion is over engineered rather than under. Suspension arms are bigger than usual, 3/4 spherical not 1/2", bearing carrier etc etc. We have opted to go for spherical bearings over rod ends as the guys are not a fan of rod ends in bending, common but weak point in design. For time and cost saving, I've decided to use the oem upright which has very strong bearings. We even had an engineer to look at the bearing and had the a ok with him.
The R35 use the same bearing. So I am confident with this.
Riverside is a very reputable sport sedan and V8 Supercar builder so I have trust in them. The car is welded to a jig, suspension arms placement are carefully calculated from Suspension 3D software for optimal geometry and are built to last. I've not tried to skim on weight here.
It's almost done. I have to give respect to Riverside and not post too much of their R&D up here. You know Liam, send him a message, he's happy to chat with you.
I'm very surprised Liam is doing a single sheer pin like that
He is very familiar with supercar front end design and I'd thought he'd go that little further and do it properly.
The upright and bearing is fine
It WILL break the alloy casting with the lower pin done that way. I've done it several times.
Save yourself the hassle of putting the car into a wall and get him to double sheer it.
I am sorry I have been away for a conference.
It sounds like the OEM upright has an inhertent weakness there. Do you have any pictures of where your previous upright broke Brad?
Anyway I talked to Liam and he said he was planning to double sheered it anyway. They are trying to also design something stronger given your information. Please load up some picture of the previous broken upright Brad.
  • 4 weeks later...
  • 1 month later...
For those that are wondering where we are up to with less than 3 months to go;
Brainstorming is completed and my final design/ideas have been sent to the Advanced Composites. A few more kilo of carbon and the car battle armour will be ready for testing ^_^ We should be ready for WTAC in October.
This will be one angry GTR when done. I am finally happy with the final design. Watch this space ;)
In the mean time, gotta work harder to pay for this hobby/carbon lol
Edited by 9krpm
  • Like 1
  • 5 weeks later...
I have a little guessing game going on with the link below if anyone keen for a free track ride in this thing
https://www.facebook.com/WorldTimeAttack/posts/676475822364927?notif_t=story_reshare
https://www.facebook.com/photo.php?fbid=621906527829788&set=a.621930421160732&type=1&theater&notif_t=like
Will try to update this thread but probably be after WTAC....under the pump atm.
Edited by 9krpm
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
