Regretfully for sale is my '96 R33 GTS-T. It has been upgraded far beyond factory spec to produce a reliable 520hp (dyno'd at 427rwhp @ 19psi) with greatly improved brakes and suspension. In addition, being a series 2 it has the newer styling, dual airbags, newer interior as well as many other improvements from factory.
Body/paint is in great nick apart from a couple of minor detractions. Interior is practically like new. The car's appearance is mostly stock apart from wheels and and a couple of extra guages. It's a real head turner.
It's had probably $60k+ spent on it in the last few years. Engine was rebuilt around the 100k mark and has performed 10k faultless kilometres since. Always run on BP Ultimate 98 and serviced religiously. New clutch and fuel pump only a couple of thousand k's ago. Modifications include:
ENGINE
Engine rebuilt (fully blue-printed, run-in and tuned)
Balanced crank
Pressure tested block
Wiseco forged pistons
Eagle rods
ARP rod bolts
ARP head studs
Big end oil mod (for better big end lubrication)
JHH ported head
JHH valve springs
Port matched head to manifolds
1.2mm 3-layer cometic headgasket
Gready Style plenum
80mm billet throttle body
Garett 35/40 with .82 rear housing
42mm External wastegate (plumbed back into the exhaust so it's legal)
Stainless steel high mount exhaust manifold (modified for better wastegate flow)
Tomei Poncams 256/256 8.8mm lift
Adjustable exhaust cam gear
OS Giken twin plate clutch (fully rebuilt - very heavy duty but comparatively light pedal)
Redline gear box oil
Stealth plumb back blow off valve (legal)
Custom intercooler piping
600x300x76mm front mount intercooler
Oil cooler (mounted behing front bar)
Speedflow fittings
Braided lines
550cc Nismo Injectors
Splitfire coil packs (brand new)
N1 OIL PUMP
Genuine Nissan water pump
New idler bearing
BLITZ SBC ID iii D SPEC Boost Controler
Power FC & hand controller
Fuel pressure regulator
Bosch 040 fuel pump (brand new)
Gates Pro Series timing belt
Custom 3" turbo back exhaust in stainless steel
3" high flow cat
Z32 air flow meter
K&N pod filter (mounted in front guard for cold air, bolted in for legality)
Full S2 M-Spec body kit with rear pods still intact
Iridium spark plugs
Blitz oil catch can
Gearbox has OS 4th and 5th gear set, fitted by Diff Laping at Kedron
RDA slotted rotors all round
Piston kits on all calipers
Paduate race pads all round
Dot 5 race fluids in the brake system
Reconditioned master cylinder with bored out piston for greater response and feeling
Engine built and tuned at 101 motorcafe, Springwood. Tuned by Rob.
WHEELS AND SUSPENSION
Rims - 17" Volk TE37 rims powder-coated silver
Tyres - Kumo 255 rear, 235 front
1" lowered king springs all round (sits a very legal 150mm from the ground)
Bilstein shocks all round
Whiteline sway bars front and rear
Tomie electric HICAS lock kit with shims
INTERIOR
G-Tech on-dash Apexi turbo timer
Blitz exhaust temp gauge
Blitz boost gauge
Pioneer cd/mp3 head unit
Pioneer 6 1/2" splits
Power FC hand controller
Piller mount for Blitz gauges
Clarion A class 12" subwoofer in boot (straped down to prevent movement)
Phoenix gold amplifier
3 point battery backup alarm
Driver and passenger airbags
EXTRAS
Custom Ferrari candy yellow paint job
Custom front bar mods to suit intercooler
Remote for head unit
Locking nuts
Full set of Nissan Skyline floor mats ($400)
Rear adjustable castor rods
Set of factory wheels
Rust free
As can be seen, the car was built as a serious drift/drag car but has rarely been on the track. I've had her as a very fun every-other-day driver for over a year and I'm only selling as I have a new daily driver and have a project car too. Priorities have changed.
I have just put 6 months rego on and I am selling with QLD roadworthy and registration so it's ready to turn the key and drive. Will sell for less without RWC/rego.
Also included are a few spares including full set of factory rims (with tyres).
Please only call if you've got cash ready or you can definately get finance. No time wasters or test pilots. Private numbers will be ignored.
Happy to send more pictures for anyone interstate.
Price is $19,500 and is negotiable. QLD rego until April 2011.
I am located on the Gold Coast, QLD.
Call Byron on 0409 49 3334 (no private numbers), email [email protected], PM or reply here and I'll be happy to answer any questions!
Edited by heycharger
  • 4 months later...
BUMP
Big price drop...now only $15,900, open to offers.
You could not buy an R33 and make it anything like this without spending some serious $$s!!!
Also have just put another 6 months rego on and new tyres.
  • 3 weeks later...
  • 3 weeks later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
