Hi guys i have looked but cant find anything...
im thinking of putting some king spring onto my 34 gtt, just the lows as i have only the std schocks..anyways what i want to know is, how much lower the car will actually get?? they say 35mm but i havent seen anybody write how low it actually went, imo 35mm really isnt that much lower.
Anybody with them fitted could u give us a height ur car is sitting and maybe some pics too. duz it look good at the lower height??
Thanks guys.
https://www.sau.com.au/forums/topic/346238-how-low/
You will find that you car wont actually be 35mm lower. YOur current springs would have sagged a bit over time. The Kings are 35mm lower from the stock springs when new. SO if your std springs have sagged 20mm then it will only be 15mm lower than it is now.
I know it is a fair bit more, but it is well worth waiting a bit longer and saving for some coilovers or some matched springs and struts.
https://www.sau.com.au/forums/topic/346238-how-low/#findComment-5575623
get coilovers. wind it all the way down till your rail/exhaust hits the ground. wind it up 5mm. done.
My thoughts exactly when I read the first post.
(aside from the toilet paper roll length list of things its going to screw on the suspension geometry)
https://www.sau.com.au/forums/topic/346238-how-low/#findComment-5587509
get coilovers. wind it all the way down till your rail/exhaust hits the ground. wind it up 5mm. get told by guy doing wheel alignment you have 30 degrees of negative camber he can't take out, put hat on backwards, say "sick", drive off, get defected, raise car, curse cop, done.
re-fixed
https://www.sau.com.au/forums/topic/346238-how-low/#findComment-5588037
