Here you go, save you a couple of dollars
The x force dump fit, I use to use one
Cheap cat
Could use the exhaust and play approx $200 to get it modified to suit the stagea
http://www.skylinesa...ls-disc-rotors/
I HAVE IT !!! i bought it from Darren ,it fited perfect...atm i have it with a catco 3" cat and fujitsubo catback(very quiet),if you have the stock turbo get an electronic boost controller because with the 3" dump and catback turbo spools faster and with manual controller you will have lots of spicking.
In this game of getting more power money is the ruler but you can do it step by step..good flowing panel filter/pod and catback should be first in your list ,them you can get a EBC and put it up to 10psi(safe boost with stock turbo),at that moment you will feel you are starting to get real power since stock standard...
