Undoing The Locking Nuts On Suspension Tops.
Hey guys,
Bought some standard shocks for my 33 gtr, only need the tops off them (couldn't give a stuff about springs/shocks) but for the life of me can't get the nuts undone at the top of the shocks (the ones on the massive thread). Don't want to strip the nuts so does anyone know of any tricks. If all else fails i'll cut the springs to release the pressure on them.
Tried wd40 and such, the nuts slightly turn, but then I realised it's the internal bit of the shock turning with them.
Any tips?
Cheers,
Ash
get a nice big breaker bar on it and then give sudden pulls on the bar, don't just gently apply pressure as they will turn the whole thing. if you are jerky in your movement you will have more chance in 'cracking' it and getting it undone.
Coil compressors wouldnt be better than cutting the springs as a last resort? :D lol
Yeah tried that too lol. The stock springs are too long for the compressors I have, so did them a bit down at either end and couldn't get enough force on it to relieve the tops. The springs are pretty crappy though anyway so no big loss if they must be destroyed :)
hehhe, good luck with that.
I ened up having to hacksaw it off (very very carefully so as not to saw the thread on the top of coilovers).
Breaker bar and the best socket available so you dont round the nuts off and wind up where i was...
Umm, sorry to ask the obvious but you're holding the top of the strut still (above the nut) whilst trying to undo the nut yeah? Like this (from the coilovers thread):
One of my front struts had the top bit cracked so I ended up sawing the strut in half to get the spring out, lol. Had I only had a pair of locking pliers...
I then put the remaining top half in a vice and finally got the top nut off, just in case I need the strut top for something else later on.
Yeah that's the bit mate. Can't find anything grippy enough to hold onto the tiny flat bit at the top of the thread. The whole strut (inner bit) just turns when I undo the nut.
Will give the breaker bar a go, however if that fails then will break out the grinder!
So you're trying to take the top nut off without compressing the springs?
Yes, my compressors are about a coil too short for the standard springs. It wouldn't be worth me buying longer ones, since I couldn't care less about spring integrity and have a grinder on hand.
Just compress the middle coils, that should give you enough slack to get the top nut off. I used something similar to the SuperCheap tool and it worked fine on R34 GTT stock springs.
Rattle gun will whip these nuts off.
Some shocks have a D shaped shaft where it passes through the spring perch, which gives you something to stop it rotating. Others have an internal hex which lets you use an allen key (with a ring spanner). Best method tho is a rattle gun. Even if you don't own one, take it to your favourite suspension place and they'll ususally undo the nuts for you for a small fee (probably zero if you ask them nicely, or actuaually ever buy stuff from them). They will also have the spring compression stuff to do it all safely.
Another way to compress the springs is to undo the nut while the struts are still in the car. Then jack it up and remove the whole lot (there are several ways of compressing / jaciking off a stub axle etc to make it easier depending on how hard it is to get the strut out, but that's too much to type coz I'm a lazy bastard)
+1 taking it too your nearest suspension shop, rattle gun take 10 seconds- you shouldn't take the nut off without compressing the springs in case the stored spring energy which is now suddenly released imbeds the strut top into your skull.
Compress the spring as much as you can. Put an open end spanner on the nut then get a shifter and grab the top EXACTLY like V28VX37 has given a pic of above. The wrench can be locked from turning on one of the 3 screws.
this will work. BTW, these should come off very easily, they are only to be tightened to 20Nm or some such, not compressed the entire way down the shaft and locked at the end of the thread.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
