I noticed that after every drive I can smell burnt oil. I can't seem to find any leaks. When I had the car checked out a month ago by Stateroads they mentioned there was a slight leak/seepage "around the engine" and from the turbo.
Is this why I'm getting the smell? What should I do...
https://www.sau.com.au/forums/topic/346256-burning-oil-smell/
Check te passenger side rocker cover toward the rear.. Common prob.. Mine was leaking a little.. Got $$ off my sale price.. The oil can slowly leak out there and run onto the turbo area causing the burning smell.. Nissan should be able to get u the gasket no probs cost me $26
As state roads told u it may be the turbo that's just coz the smell and or smoke generally comes from that area but it's so hard to see specifically. They told me the same thing..
If that's not the prob keep looking and make sure ur oil levels are always good..
See how u go..
Edited by matty_M35
usual leaks are
1) around the spark plug closest to the passenger (is a know spot to seep on VQ motors)
2) oil around the turbo. Is a bitch to get to with the heat shields.
Other option, put your vents on Recycled air.. lol
See how u go..
:D
Usually this oil will leak onto your turbo as Matt said or even the heat shields which obviously get very, very hot.
usual leaks are
Hmm I can only smell it when I get out of the car - I dont smell it with the air vents on.
So I need to replace the gasket...eek how much will this set me back?
Oil levels are fine - I changed the oil 2 weeks ago and it certainly wasn't low. A good 4-5 litre of old oil drained out. I replaced it with 5L of Mobil 1.
ive got oil line leaks on the stock turbo not huge but evident. bit of a worry. - which is no doubt helping kill this turbo prematurely.
only just noticed since i got under there to pull the starter out - new braided lines and speedflow connections will smack that on the head with the hiflow.
i think ive also got a rocker cover leak on the passenger side.. so when its engine out time for the turbo replacement (when i can afford it) that gasket number will come in handy. thanks.
:- got my donkey syringe ready also for the spark plug change.. expecting cylinder 1 to look like a mote of oil.
think i might leave my car at jetwrecks and see if he wants to pull my engine out for me.
Edited by PetroDola
So just ask for gasket for a VQ engine?
I was more worried about the labour. I'm not terribly mechanically capable - maybe I'll ask Scotty to fix it when I take my car in for the exhaust job :(
scotts m35 zorst centre.. at scotts house.
hehe , suprised hes not asking for an hourly rate ;)
well i just got off the phone to nissan.. sobering very sobering.
apparently the 2002 nm35 stagea vq25det part number for a starter motor is this :- 23300-AL600 -$1400 3 weeks to order none in country
the j32 maxima does not suit.. the guy was looking at the bolt pattern its different again.
there was also a 2002 350z one with the part number 23300-AL900 that was $1495 - none in country and also 3 weeks to get in. (the 02-07 350z have 4 different part numbers and he wasnt sure)
hmm.. looks like starter motors are more of a bitch than once thought.
also that part that you quoted me iamhe77 the nissan parts guy said it was a bolt :( - unless he was clueless.
$1500 and 3 weeks though.. that sucks.
Edited by PetroDola
Had to re-read your post, I was going to say $1400 is a little steep for a gasket...lol
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
