OS Giken 5 Speed Box R34 RB25
Custom order, ratio's setup for a drag car. Recommended use with 4.3 final ratio.
Has about 10 000km's on it, comes with shifter bent forward to suit S13/4/5.
I can supply with SR bellhousing welded on for another $750
Ratio's are
2.516 1-speed
1.703 2-speed
1.236 3-speed
1.1 4-speed
0.870 5-speed
$4000
0401 151 011 or PM for contact. I can post anywhere is Aus at your own cost.
https://www.sau.com.au/forums/topic/346264-os-giken-r34-gearbox-rb25/
hay buddy
is this the full gear box or just the gear set.
is it the 1-3 or 1-5
does it come with input shaft
can u convert the shifter back to r34 spec
thanks
julz
hay buddy
thanks
julz
its complete, was just taken apart for inspection.
its 1-5.
the shifter looks like its been heated up and bent near the base, it wouldn't be hard to straighten it.
  • 1 month later...
this is taken off otomoto website
5-speed $4960 includes strengthened input shaft
The gears in this kit are rated for 1200hp, however due to the limitations of the Nissan synchros above 9000rpm, it is generally best suited to applications up to 800hp
keen mate but gotta see if i can get my hks triple plate back, got rid of it to go auto will contact u a soon as i know, not interested in swaping for a dirt bike? just thought i'd ask
