Hi guys and gals, yesterday I crashed my car into someone parked ileagally and as a result I have for sale my series 1 R33 1994 model skyline it does have a few parts you may want. Cant be drivren on the road but can be driven onto a tow truck or car trailor, it still starts, the mods that have been done are:
- Slpit front dumpipe
- 3" Hks exhaust system with a 6" cannon
- Nismo fuel pressure reg
- GTR fuel pump
- Oil filter relocator
- big front mount intercooler
- Boost controller
- HKS turbo timer
I cant remeber everything right now I will update when I can remeber other stuff I would like to sell the car whole as I get really sad every time I walk outside the I am asking $4000 for the lot there are heaps of other parts on the car and will update when I can. If you are interested please give me (Loof) a call on 0403379309 and please dont post if you are going to be negative. I live in the Penrith area
Also just got Peter at Advan performance to change my timing belt all bearings and he also custom fitted a GTR water pump to the car last month.All parts where brand new I still have receipts.
Tyres onthe front have 99% tread I bought them about 3 weeks ago the 2 tyres on the back have about 90% tread
Also has Sony explode sterio and Pioneer splits in the front doors
Got the power steering pump reconditioned in October
https://www.sau.com.au/forums/topic/346297-just-crashed-my-r33/
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
