Hi guys and gals, yesterday I crashed my car into someone parked ileagally and as a result I have for sale my series 1 R33 1994 model skyline it does have a few parts you may want. Cant be drivren on the road but can be driven onto a tow truck or car trailor, it still starts, the mods that have been done are:
- Slpit front dumpipe
- 3" Hks exhaust system with a 6" cannon
- Nismo fuel pressure reg
- GTR fuel pump
- Oil filter relocator
- big front mount intercooler
- Boost controller
- HKS turbo timer
I cant remeber everything right now I will update when I can remeber other stuff I would like to sell the car whole as I get really sad every time I walk outside the I am asking $4000 for the lot there are heaps of other parts on the car and will update when I can. If you are interested please give me (Loof) a call on 0403379309 and please dont post if you are going to be negative. I live in the Penrith area
Also just got Peter at Advan performance to change my timing belt all bearings and he also custom fitted a GTR water pump to the car last month.All parts where brand new I still have receipts.
Tyres onthe front have 99% tread I bought them about 3 weeks ago the 2 tyres on the back have about 90% tread
Also has Sony explode sterio and Pioneer splits in the front doors
Got the power steering pump reconditioned in October
https://www.sau.com.au/forums/topic/346297-just-crashed-my-r33/
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
