This is a spur of the moment thing but As the weather is going to be good on Saturday why don't we catch up somewhere central for a meet. As there is probably only 4 or so of us on here I hope thatbthis message is not to fall on deaf ears. Just send me a PM if interested and I will organize a time and place.
https://www.sau.com.au/forums/topic/346317-att-vic-owners/
I'd join you if you were in Adelaide! Far too much work lately and not enough GT-R seat time! ;)
You might be able to join us in Melb next year...
There is something very very big brewing at present between SAU-VIC/SA/NSW. :)
Will pay to be a members thats for sure...
https://www.sau.com.au/forums/topic/346317-att-vic-owners/#findComment-5578379
r all the clubs joining because everyone is stepping down ??
https://www.sau.com.au/forums/topic/346317-att-vic-owners/#findComment-5578426
betta be end of novermber or december coz thats wen il have my gtr n my license back :D
https://www.sau.com.au/forums/topic/346317-att-vic-owners/#findComment-5585629
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
